Results 1 to 4 of 4
Thread: Broken Steering Wheel Volume Button
    StealthCalais Guest
    Default Broken Steering Wheel Volume Button
    Hi all
    Well unfortunately I managed to break my volume up button on the steering wheel controls grrrr! (not suprisingly... potentially a sign I should turn the volume down :P)
    After reading a few threads on what the options to fix this issue are im still undecided. I can either go to holden and fork out $150 for whole new set of buttons (what a scam, have to buy both units together) and get them to replace at extra cost no doubt...
    OR
    VZ Radio Buttons
    There is a neat little fix that someone has done to repair just the one button - its a good idea in concept and apparently it was still lasting after a few months, but hard to say. Additionally, it involves removing the airbag and disconnecting bits and pieces, which ordinarily I'd be keen to try - but given its the airbag I dont want it to blow up in my face!
    Has anyone had much experience with fixing these buttons or removing the airbag etc. Pointers, ideas, tips, suggestions would be appreciated! Cheers
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by StealthCalais View Post
    Hi all
    OR
    VZ Radio Buttons
    I can report that my heavy handed wife has not busted the repaired button as yet. I did not remove the air bad as such - just flipped it up while I undid the 2 screws holding the buttons in. It is a very cheap fix using some cloth and super glue (in very small amounts).
    and 3 Dangerous non ABS VN's
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    As for airbag removal, there is a How-to on VY/VZ steering wheel rermoval. Don't know about the button repair, havn't done that.
    VZ lumina Executive
    Jan 2009
    qld
    its quite easy to remove to remove the steering wheel, I had a broken volume button. I disconnected the + and - connection . Left it for 15 minutes. to drain any electricity. then removed the air bag . and you can get access to the volume control buttons. removed then . super glued them . left it for 2 hours to dry. and it has been 5 months. never had any issues.
  1. broken volume button on steering wheel
    By kimbo5 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 21-11-2009, 03:43 PM
  2. Broken steering wheel button
    By CMA in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 18-09-2008, 09:22 PM
  3. Steering Wheel Radio Volume Button
    By SV6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 25-08-2008, 05:37 PM
  4. Steering Wheel Volume up button
    By jordanaki in forum VY Holden Commodore (2002 - 2004)
    Last Post: 25-10-2007, 01:06 AM
  5. Broken Steering Wheel Controls Button
    By mriksman in forum General
    Last Post: 28-08-2007, 09:24 PM
