Results 1 to 15 of 15
Thread: vz performance issue
    VZ lumina Executive
    Jan 2009
    qld
    Default vz performance issue
    Hi guys,
    My car is having performance issues. I always fill 98 octane fuel. I have to press the peddle down hard to get upto 60 k/hr . Looks like engine is taking too much power to move the car. I have checked air pressure.
    Tyre are brand new
    Recently topped engine oil
    Coolant is full
    No error codes shown at all.
    I suspect will it be spark plugs ? . Is there a way to find out ?
    Any suggestion would be appreciated. Thanks in advance.
    Darcon666's Avatar
    Darcon666 is offline Evil is always around you
    The Wife
    Jun 2010
    At home
    2009 VE SS SILVER SEDAN
    Sep 2008
    Brisbane, Queensland
    coil packs? .... depends if it's missing on acceleration................ OR if your just driving on really hot day, it's probably just knocking like crazy (engine wise). If it's heat try a Mace Manifold Spacer..... they help a tad
    2009 VE SS SILVER SEDAN - Twin Amps... Tune in progress (more for response and power) then outright KW on a dyno
    VZ lumina Executive
    Jan 2009
    qld
    VZ lumina Executive
    Jan 2009
    qld
    Darcon666's Avatar
    The Wife
    Jun 2010
    At home
    You never said it was missing.... does it miss while in neutral(No load...)?
    Coil packs(As mentioned..), Injectors, Plugs, Slipping torque convertor, Gearbox oil low(auto)... pcv/vacum leak, Knock sensor, TPS... would be the tings I would look at first.
    Good luck.
    VZ lumina Executive
    Jan 2009
    qld
    i am just suspecting that it is spark plug as i have to press the accelerator half way down to achieve 60 k /hr . it is not missing. thanks for help !
    VZ lumina Executive
    Jan 2009
    qld
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    VZ lumina Executive
    Jan 2009
    qld
    VZ lumina Executive
    Jan 2009
    qld
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    So, what exactly would you put that down to (replaced plug(!!)) a lack of maintennance or part failure ? Why did you only change one plug when you consider the amount of work to get access to them.
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Logic tells me he did replace them all and simply made a typo.
    Silver Certified.
    VZ lumina Executive
    Jan 2009
    qld
  15. #15
    CRUSTIN is offline P-plater
    VZ S 175 Ute
    Nov 2010
    I'm surprised it was the plugs cause normally you would feel the miss, or notice the engine note changed. And when a plug fails, it fails all the time, so idle would be rough.
LinkBacks (?)
  1. 23-10-2011, 12:04 AM
  1. V6 Ecotech Performance Chips & Bolt On Performance Parts
    By MR.HG in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-12-2010, 02:39 PM
  2. Tuned Alloytec 190 Performance Issue?
    By mrdunu in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 13-10-2010, 07:27 AM
  3. Alloytec 190, Performance Issue?
    By Owned in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 21-07-2010, 02:21 PM
  4. performance?
    By sydd131 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-04-2009, 07:53 PM
  5. VX Series 2 Executive - Start Issue + Boot Button Issue!
    By stig1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2008, 02:28 PM
