Results 1 to 14 of 14
Thread: coolant leak near transmission
    VZ Executive
    Dec 2010
    Default coolant leak near transmission
    a couple of days ago my vz executive sedan was overheating and the coolant boiling. i originally traced this problem to a faulty radiator cap which has now been replaced along with flushing the system and refilling the coolant which seemed to fix the problem
    i went to change the oil in the engine this morning and have now noticed that there is a coolant coming from somewhere near the rear of the transmission though i cant get underneath the car properly to find the leak. it only appers to leak when the engine is running,
    am i right in thinking that its probably from a hose or is it possibly something worse?
    my only concern is that the transmission has also been shifting roughly lately and am wondering if it could be related.
    Sabbath''s Avatar
    Sabbath' is online now Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Could possibly be a thermostat housing and running along the trans. The rthermostat is drivers side, right at the back of the motor above the bellhousing, so it's plausible
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    5.7L VZ
    Jan 2010
    Nthn Beaches, Sydney
    Prob your heater core leaking and it's coming out the drain tube.
    CHECK OUT MY RIDE!!!
    VZ Executive
    Dec 2010
    yeah im sure its coolant not the atf
    ill have a look into the heater core and the thermostat
    VZ 2005 Executive Wagon
    Sep 2009
    Northern suburbs of Adelaide
    Quote Originally Posted by coxy47 View Post
    Also, I would make sure that if you have been operating the airconditioning, it is not being mistaken for water from the airconditioning evaporator drain port, as it also discharges around the transmission area.
    VZ Executive
    Dec 2010
    Quote Originally Posted by bcw61 View Post
    unfortunately its not the aircon discharge because it is a red fluid
    Sep 2009
    Buggar!!! I feel your pain. Almost cooked my engine completely over Xmas, when the coolant decided to exit prematurely whilst driving on an isolated dirt road in the Vic countryside. Water pump/gasket decided it didn't want to play nice anymore. Not much fun driving with the overheat and drivetrain alarms going spastic, the transmission locking up the torque converter (thought I was driving a manual again) & hoping like hell the overheat protection mode worked OK.
    vz acclaim
    Jun 2006
    LOL i have this problem aswell but only after i changed my waterpump, pressure cap, pressure cap housing orings and my heater tap now its leaking from the f#$%ing thermostat housing wot next
    TEAM CLOWN RACING
    VZ Executive
    Dec 2010
    i have now traced the problem and it appears that the is leaking
    cheers for the help
    VT Berlina S2 V6 + VZ Acclaim Wagon
    Jul 2005
    Sep 2009
    [QUOTE=wot next[/QUOTE]
    Well, I suppose you still have the welsh plugs left to go next. Something to look forward to LOL.
    vz acclaim
    Jun 2006
    why wouldnt that suprise me and once ive fixed the welsh plugs it'll start coming out the head gaskets
    TEAM CLOWN RACING
    VZ Executive
    Dec 2010
    sorry for my idiocy it was the heater core thats leaking
  1. VX Coolant leak from Coolant Reserve?
    By anarklov3r in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2010, 09:50 AM
  2. Coolant Leak
    By inais in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-08-2009, 11:19 AM
  3. Big coolant leak
    By Rithumanbloos in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-06-2009, 10:28 AM
  4. New Radiator can cause Transmission leak? Inhibiter instead of coolant?
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-01-2009, 10:44 PM
  5. VS III V8 - Coolant Leak
    By mosscano in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-08-2008, 04:32 PM
