Results 1 to 9 of 9
Thread: Possible Starter Motor Issue??????
    VZ Executive
    Jan 2011
    Default Possible Starter Motor Issue??????
    Need someones opinion.
    Every time I start my VZ now it cranks and then ticks a few times and then finally starts.
    I have checked the alternator and it is charging at 14.4 and the battery holds a charge at 12.5 when the car is off.
    Could this be a starter motor issue?
    jetboy's Avatar
    jetboy is offline You learn til u die
    VT exec
    Feb 2010
    Gold Coast QLD
    Most likely , get under an check the terminal on the starter where the main power feed from the battery connects to an give it a good wiggle , if its loose then ur starter is shot . If not how olds your battery?? it may be on the way out . Also check that your battery terminals are in good condition and are clean and tight
    At 43 a wealth of info , but still heaps to learn
    jetboy's Avatar
    VT exec
    Feb 2010
    Gold Coast QLD
    Another thing is to drop test your leads , Goggle "voltage drop test " and you will find instructions on how to do it , its a bit in depth to post here
    VZ Executive
    Jan 2011
    Thanks for the quick reply.
    Not sure how old the battery is. I'd say it a few years old but it seems to be holding its charge. I will check the wiring though.
    Thanks
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Just cuz the battery appears to be 'holding a charge' spear mean so. I thought the same thing, had similiar problems but replaced the battery and all was better, or, have u checked that the car is slow draining the battery?
    If ur in Brisbane I can get you a battery for $36
    Life starts at 200km/h
    vnss
    Jan 2007
    wyndhamvale vic
    yeah mate check your battery first as it can hold charge and will be taking 14.5 from alternator but if it has dropped a cell it wont have enough cranking amps to turn over the starter....take it to your local auto shop if their half decent they'll check it for you....
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Have your battery 'load tested'. Even though it may seem to have sufficient voltage it may not be capable of producing high enough voltage to handle the starter motor. If it is 2 - 3 years old then it has probably reached the end of it's useful life.
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    VZ Executive
    Jan 2011
    G'day.
    I jumped started the vehicle today to give it more power and started first go without any problems so i will be changing the battery.
    Thanks for your help.
    Matt
  1. VR V6 into Hilux - no start issue
    By Grega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-07-2010, 09:28 PM
  2. What the **** was that... engine start up issue
    By dirtjumper005 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-10-2009, 09:31 PM
  3. Issue: Won't start when warm.
    By lukefraser in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-12-2008, 02:34 PM
  4. VX Series 2 Executive - Start Issue + Boot Button Issue!
    By stig1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2008, 02:28 PM
  5. VN Berlina start issue
    By Bongo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-05-2005, 01:42 PM
