Results 1 to 14 of 14
Thread: quick question on catback exhaust systems?
    JShaw's Avatar
    JShaw is offline greeeeeeeeen
    06 VZ Executive
    Dec 2010
    South East Melbourne
    Wink quick question on catback exhaust systems?
    Hey guys I checked the FAQ but not sure that I found my answer.
    What are the differences in the different catback exhaust systems you can purchase?
    I'm talking between 2, 2.5, 3 inch etcetc and single or dual?
    I'm keen to get one very soon but all these options are making it hard to choose, and i'm also not very experienced in this field so that makes it tougher!
    Finally, anyone recommend a place in melbourne/south-east to get it done cheap but of good quality? I'd like to not get ripped off, thanks!
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    They are different sizes, twin means two exhausts.. U should go a twin with 6 inch cannons, sounds wicked on anything
    It also helps for you melbourniens to go sideways around fully sick round a bouts.
    In all seriousness though, you haven't given much detail about what you want from ur exhaust and how loud u want it. Remembering that thee is not a lot of gains in cat back exhaust, jut a lot of noise
    Life starts at 200km/h
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    No loss of compression WTF?
    Better to keep your mouth closed and be thought a fool, then to open it an remove all doubt.
    If you've got a naturally aspirated (no supercharger) V6 IMO the best exhaust setup would be twin 2.25" system.
    The difference in exhaust size comes down to how much gas you have flowing through it. You don't want it too small so as to restric the gas flow, but you don't want it to big. If the Diameter is too big the gas slows down, which is bad as this is essentially the same as having it too small.
    The difference between single and twin systems. Single systems are cheaper and harder to get the best balance between flow and speed. Twin systems cost more generally due to the extra time it takes to make and the materials needed, but its alot easier to get the flow vs gas speed ratio better.
    The best thing I can recomend you do, if you're chasing power is to get extractors and some decent cats. Run a true twin system. Running single into twin is like drinking non alcoholic burbon... (ash water). It will just leave a shitty taste in your mouth.
    If all you're after is noise, as single 2.5" exhaust with a really good muffler is what you should go with. If money is no object, get on Ebay and hunt down an edlebrock or Magnaflow muffler and get a system custom made. Those mufflers usually go for about $250. The muffler is where the sound quality is. Not the size of the pipe.
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Lol, loss of compression. That one is going into the book of all stupid calls
    JShaw's Avatar
    06 VZ Executive
    Dec 2010
    Thanks guys! sorry about lack of detail.
    at the moment i'm really only looking for sound over performance, so as your advice goes, a single 2.5" ?
    im really just keen to get a good sound out of my vz!
    i've got just a custom muffler/tip atm and it sounds good when i plant the foot but when it's idling/foot isnt on the pedal there isnt much sound at all, which i'd like to change
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Not an abba does a good exhaust, I am surprised he hasn't been in Here yet, is it a muffler or a tip? Tip won't do anything for sound.
    If u want sound single. 2.5 with a free flowing muffler.
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    i got a twin 2.5 redback on mine with no rear resonator. me and impulsive get together fairly often so i can compare my twin with his single, but he has extractors. anyways, from what i can tell the difference, my twin sounds 'smoother' than impulsives, where as his single sounds more beefier and throatier. also on idle, his single is louder. when driving, pretty sure mine is louder, well inside the cabin is louder (drone). performance wise, i think mine would be better (courtesy of impulsesv6), i asked him because he had both, and he said the twin 2.5 gave higher dyno reading, but lost down low rpm. just something to think about. to be honest, im thinking of converting mine to a single 2.5, because i like the sound of impulsives more than mine haha
    Spoken by a true member of The Committee
    Nov 2008
    Smithton, Tasmania.
    If you want a little lope at idle you'll need extractors.
    Even then you wont get a great deal more.
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Quote Originally Posted by richardpalinkas View Post
    Let's not get carried away rich, yours is louder but not on idle. The 2.5 twin was too big an I'm sure the yuck sound the x force produced was the reason why he got rid of his, remembering that he also had it on when he was blown. I say twin 2.25 Us the best. Otherwise for sound 2.5" ftw
    JShaw's Avatar
    06 VZ Executive
    Dec 2010
    Thanks for all the advice guys, really appreciate it!
    I can only find 2.5" twins on ebay for a VZ, stupid question but a single 2.5" CAN be fitted to a V6 VZ right? haha
    May 2009
    Gold Coast
    Yea, there are lukey single systems on there for 200. Just search vz v6 exhaust
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Or just go to the shop and get one made up... Lucky ones are shit on eBay
    VE Calais, VL SL
    Mar 2009
    Adelaide Hill's
    Quote Originally Posted by impulsive View Post
    I had my Lukey made up in a shop any diffrence???
    I quite like it its only a single 2.5, deepish note for what it is, and no annoying cruising rpm droning.
    Had it tested on a mate's rolling road for the hell of it, over a half dozen runs made an average of a mighty 2.3kw more than without it.
    Instant bolt on power
    JShaw's Avatar
    06 VZ Executive
    Dec 2010
    Yeah i'm gonna ring around some exhaust places and get some quotes, thanks!
  1. just a quick exhaust question
    By stato98 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-09-2010, 12:25 PM
  2. Sorry, yet another exhaust/catback question
    By wigbilly in forum VE Holden Commodore (2006 - ?)
    Last Post: 09-09-2010, 06:32 PM
  3. Quick Exhaust Question.
    By jokerflingo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-02-2010, 10:25 PM
  4. quick exhaust question - 5.7l
    By davway in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-03-2009, 09:43 PM
  5. Quick exhaust question...
    By spd_dmn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-09-2008, 05:30 PM
