Results 1 to 8 of 8
Thread: Need info on clusters
    AzTuati's Avatar
    AzTuati is offline VZ, a cheaper VE :) <3
    05 VZ Executive
    Sep 2010
    Greenbank, QLD
    Question Need info on clusters
    Ok sorry if its been posted before but i couldnt find it and a search alot.
    I need some info on VZ clusters because ive had mixed answers from different forums.
    i have the single window cluster which from reading other threads is also known as a level1 cluster?
    i want to put in a cluster from an SV6 or Calais, or if possible a HSV cluster.
    now my questions are,
    1.I heard from some other forum that if the cluster has over 100kms on the clock you need holden to put it in, is this true?
    2.SV6 have more options than a Exec, are those options built into the cluster? eg, if i were to install the SV6 cluster into my Exec would it show those options? and would they actually work if it did show them?
    3.Another thing is would my car even take a Triple screen cluster even though it was a single screen from the factory?
    i had more questions but i forgot them, these will do for now, sorry for asking so much i just wanna know exactly how it all works so im not wasting money and so i know what to look for when i start doing up the interior.
    My VZ Project
    Looking for a custom cat-back system or CAI?
    Live in the Logan area of South-Brisbane?
    Save $$$ and PM me
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    it should fit in no worries. i think you may need to get it calibrated though to use all 3 clusters, but not sure
    Spoken by a true member of The Committee
    May 2009
    Gold Coast
    oh and to answer your questions as far as i know,
    1. i know this was applicable for vt.vx, not sure about vz though, may be different
    2. i dont think that the dash would show any extra information, that information i doubt will be stored on the dash, rather somewhere else? bcm, ecu???
    3.it should fit in, someone else can clarify if it would actually work as 3 clusters or just the one will work.
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    There is a bloke that do this a while ago, I think it was paulsv6 but can't be sure, if I can find the car I'll link you, he explains it all in there
    Life starts at 200km/h
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    I've got a 05 VZ Exec with a WL Statesman cluster in my car. I've also got a VZ Calais cluster for it also. Both needed reprogramming to avoid setting off the air bag warning and climate control. The WL needel the fuel sender re programmed also.
    The VZ 3 window cluster will work if you plug it in and then spit out air bag error unless the cluster you get has the same number of air bags programmed..
    and 3 Dangerous non ABS VN's
    May 2009
    Gold Coast
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    AzTuati's Avatar
    05 VZ Executive
    Sep 2010
    Greenbank, QLD
    thanks guy thats helped heaps, ill look a bit more into it. and thanks impulse for the link ill search it tomorrow. Might head down to Holden and ask them about it too.
    My VZ Project
    Save $$$ and PM me
  1. VZ clusters.
    By SN0WMAN in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 01-12-2010, 01:40 PM
  2. Excellent Info on REbuild for L36 or L67 Great info...
    By vxcalais_01 in forum V6 Development And Modification
    Last Post: 22-05-2010, 12:26 PM
  3. Photos of L1, L2, L3 Clusters pls
    By AlpineRaven in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-09-2006, 02:39 AM
  4. instrument clusters again!
    By bru55el in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-07-2006, 06:41 PM
  5. Swapping clusters
    By furrhead in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-06-2005, 11:16 PM
