Results 1 to 8 of 8
Thread: VZ clutch..anything else?
    2005vzute's Avatar
    2005vzute is offline Djabringyagrogalong
    2005 VZ Ute M6
    May 2010
    Glenfield 2167
    Default VZ clutch..anything else?
    g'day all,
    so i've just bought a heavy duty clutch set up for my v6 ute...the kit has the solid flywheel, new slave cylinder, new pressure plate and new clutch plate...also got new flywheel and pressure plate bolts...is there anything else i should be replacing?. is there a spigot bearing or bush i should be worrying about..its only got 82,000 on the clock and its a 05 model..if anyone could think of anything else to go with it could you's please let me know
    cheers everyone
    Quote Originally Posted by maldotcom2 View Post
    Also, always go into a corner in second gear in case you see a hot chick or another commodore you can fang it out sideways.
    Bored or just wanna talk about cars? Add me on facebook and we can talk
    http://www.facebook.com/#!/profile.php?id=1002697869
    ashbox's Avatar
    ashbox is offline 6 speed
    VZ SS 6 Spd
    Apr 2007
    The Car
    yeah i'd prob replace the spigot bearing to, i know the clutch kit i bought for my vx cam with everything apart from pressure plate bolts so i'm surprised u didn't get a flywheel and spigot bearing
    Chev badges are an instant fail
    lein's Avatar
    lein is offline Comrade Commodore
    VZ Ute
    Dec 2010
    Tropical QLD
    There's no spigot in the rear of the alloytec from memory. The reason I remember is because it's so odd. Either that or my VZ didn't have one and I should have fitted one.
    I aim to misbehave.
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    2005vzute's Avatar
    2005 VZ Ute M6
    May 2010
    Glenfield 2167
    it should..the guy done a dodgy one me but..i asked him thrice for an extreme clutch kit and he said he has it and its in stock..then at the counter he gives me pbr telling me its the same shit, which it probably is...except with a lot more ####ing around...i got the pbr anyways because i need it in a rush..i think the spigot should still be alright..its only had 82,000 on it so should be good
    VS II S Ute
    Nov 2009
    check your thrust bearing for signs of clutch dust, if that goes u r screwed, regrease it too if u can
  1. Vz clutch 190 - 175
    By VzVzVz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 21-08-2010, 02:27 PM
  2. [WA] VT-Z LS1 clutch master+slave cyl+reservoir + VX clutch pedal **SOLD**
    By savage1987 in forum Parts And Other Items For Sale
    Last Post: 23-05-2010, 11:22 PM
  3. [VIC] T56 Clutch Kit
    By ssn8r in forum Parts And Other Items For Sale
    Last Post: 22-09-2009, 03:26 AM
  4. vr-vs clutch
    By crockettntubby in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-01-2009, 12:21 AM
  5. Clutch on way out???
    By stealth_grey in forum General
    Last Post: 09-03-2006, 11:41 PM
