Results 1 to 7 of 7
Thread: VZ Exec Radio Antenna Stops Partway
    VZ Executive
    Jul 2010
    Hampton Park
    Default VZ Exec Radio Antenna Stops Partway
    My radio antenna now stops partially extended, not enough to pull in FM stations clearly. There are no mast controls on the single disk head. Anyone know how to get it to "remember" to go all the way up?
    VZ Wagon
    Dec 2008
    Clean gently with Inox spray and rag. Carefull not to bend. Try and slide all tubes again lubricate with Inox. When all part move free. Turn radio off. When antenna has retrackted back on again. Repeat untill it fully extends.
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Check it has not got a slight bend in it as this can cause them to not fully extend/retract.
    HoldenOnn's Avatar
    HoldenOnn is offline Roll Cage Territory
    VZ Calais Alloytec190
    May 2009
    Busselton, WA
    Agreed with the 1st reply. Although I use stainless/alloy polish on mine in my Calais as the same thing occassionally happens to me. Sometimes you need to be a little forceful and pull hard to unstick the aerial and then you can go about cleaning it. Goodluck.
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    try cleaning it OR replace rope and mast from holden if its a damaged mast
    or if its clicking when it stops it might be a new aerial motor (comes with new mast)
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    It says in my owner's handbook not to lubricate the antenna mast. I just use some Autosol occasionally to keep it nice and shiny, but be sure to remove any excess.
    VZ Executive
    Jul 2010
    Hampton Park
    All good now, thanks guys; pulled it up to full length, cleaned the mast with some warm soapy water (aka car wash) and gave it a very light wipe with Inox and it rose to full length quick as!
  1. VE Radio/Antenna Delay???
    By KathyB in forum VE Holden Commodore (2006 - ?)
    Last Post: 20-11-2010, 03:56 PM
  2. Connecting antenna wire to radio antenna
    By Denno in forum Electrical Wiring / Questions
    Last Post: 02-04-2010, 05:23 PM
  3. radio antenna
    By half in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-09-2009, 03:41 PM
  4. VS Radio Antenna
    By PSYKO PHOENIX in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-01-2009, 07:00 PM
  5. VT Radio Antenna
    By Hubba in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-01-2006, 12:16 AM
