Results 1 to 3 of 3
Thread: BCM Indicator getting stuck on work around
    '04 VZ Executive, '98 EL Falcon, '96 NF Fairlane
    Jul 2008
    Blue Mountains, Sydney, NSW, Australia
    Default BCM Indicator getting stuck on work around
    Hey all,
    (Off the top of my head, will correct if wrong when i get home tonight) Just pull the "power antenna fuse" out from under the steering column. The hazards dont work and the indicators dont flash when locking and unlocking the car but the indicator doesn't get stuck on and the antenna still works (on my car not sure about other vz's) and also the indicators (turn signals) will still work.
    This is done on my car i am not liable for any damage done you and or your car.
    [Linkin Park] Concerts:
    [20.10.2007, Sydney Entertainment Center, Sydney NSW] [11.12.2011, Acer Arena, Homebush Bay, NSW] [15.12.2011, Acer Arena, Homebush Bay, NSW]
    Vehicles:
    [2004 VZ Holden Commodore Executive V6] [1998 EL Ford Falcon GLI Manual Inline 6] [1995 NF Ford Fairlane Ghia Inline 6]
    azazeldeath's Avatar
    azazeldeath is offline Donating Member
    VZ Holden Crewman 06 6sp S pack
    Oct 2010
    Darwin, NT
    Or you can disable it from the menu on the cluster. Turn the car on, press Menu (if I remember correctly) then it will let you change the options from there. Worth trying that first since you can change it from indicators, to horn to nothing if I remember correctly.
    Jul 2008
    Quote Originally Posted by azazeldeath View Post
    Its from "indicators" to "indicators & horn"
    Vehicles:
  1. Speedo/alert won't work - replaced cluster, still won't work
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-05-2011, 10:33 AM
  2. VR 1994 Indicator doesnt work (Hazard lights work)
    By rester in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-09-2010, 01:40 PM
  3. Indicator holder around steering column stuck in an awkard position
    By mark_d in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-02-2010, 09:31 PM
  4. Speedo/alert won't work - replaced cluster, still won't work
    By VS Omega in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-02-2009, 06:54 PM
  5. Indicator Gets Stuck
    By damez in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-10-2007, 10:44 AM
