Results 1 to 8 of 8
Thread: HELP. ecu unit may be gone.
    04 vz executive - 87 vl executive
    Jan 2011
    perth
    Default HELP. ecu unit may be gone.
    hi, need some advise on the following issue. approx 6 months ago my 04 vz exec, started to run a little rough, it continued to get worse until the motor started cutting out. it is now at the mechanics where at first they said it was a faulty key, so they got a new key and programed it to my car. now they tell me that the new key wont start the car and the old one doesn't work. the mechanic seams to think that the ECU is a little dodgy and is waiting for an "expert" to get back from holidays so he can look at the car.
    1- can the ECU be fixed?
    2- how much is a new one?
    3- what aftermarket ECU's are available and how much are they?
    any help would be much appreciated.
    cheers mike
    VY SS
    Jun 2006
    Albany
    sounds like you need to find a new mechanic lol you wouldnt think a faulty key would cause the car to run rough, and if the old key wont even start the car after they programmed a new key and even the new key wont start it maybe they did something wrong when trying to program the new key
    Dangerous Dave is offline Donating Member
    VS Berlina
    Mar 2009
    erm, someone correct me if i'm wrong, but VZ key programming is all in the BCM, not the ECU....
    2 very different items.. unless there is a comms fault between the 2, but that would mean the car wouldn't have started even before the key was introduced...
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    new ecu's are expensive to install and tune... and you need one to match the model/series (standard ecu) and year of your car, hard task ahead of you.. i agree with Mr Danger Above, try a new mechanic lol
    Life starts at 200km/h
    Little Red VZ Go-Kart's Avatar
    Little Red VZ Go-Kart is offline Middle-age mutant ninja
    Ex-CFA VZ 175 Commodore Exec. 06 wagon
    Aug 2010
    Democratic People's Republic of Highton / Geelong
    Quote Originally Posted by mike87 View Post
    cheers mike
    The mechanic says it is the ECU. Other posters here rightly point out the connection between the remote keys and the BCM, yet neither of these seem relevant to the bigger issue of investigating the engine, e.g. injectors (especially), ignition module, alternator, battery ... what else? Perhaps a dying fuel pump? I cannot imagine a qualified and skilled mechanic passing off something like this as being strictly a problem with the ECU (all other possibilities having been duly eliminated — the question then is, have they?).
    •:*จจ*:•.When you start your car, does it return the favour? •:*จจ*:•.
    Originally posted by soop
    Your arse is going to sting for a while, and then worse when it does bugger all.
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Usually in a sever case like this would t I throw up a misfire code ???
    2DIE's Avatar
    2DIE is offline ONEDOLLAHOLLA
    97 Acclaim
    Feb 2008
    South Aus
    You can probably send yours away to get re flashed or..
    PCM / ECM / ECU
    New ECU
    Mail Order Tunes / Memcals
    New tune.
    You could probably ask them to put a tune you want on the ECU then send it to you, ready to bolt straight in and go.
    I saw a guy the other day talking about a change over mail order ECU with a tune for his VX from these guys, it not real cheap but better than not having a car running I guess.
    Best RPG ever
    vz calais 190KW A5 CHE TUNED
    Feb 2009
    SmithField NSW
    If you are goin with a new ECU will cost u bout 2k + its the ECU n the reprogramming thats expensive. To fit it is piss easy.. i got mine replaced recently cost me 1.2k not a brand new ecu but cars running.
  1. New pioneer head unit - problems with old stock unit
    By thejdizzle015 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 22-07-2010, 05:19 PM
  2. [SA] VS HVAC Unit (Fan/Heater/Cooling Unit)
    By seraphic06 in forum Swap / Wanted to Buy / Trade
    Last Post: 23-11-2009, 01:49 PM
  3. Replacing VT head unit with BT ipod unit
    By nickbedford in forum Car Audio
    Last Post: 23-06-2009, 03:00 PM
  4. VY to VZ Unit
    By Menz in forum Car Audio
    Last Post: 01-05-2008, 10:10 AM
  5. just got my cd unit put in
    By VSSPak in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-05-2006, 09:01 PM
