Results 1 to 10 of 10
Thread: New Rotors (Is There A Running In Period?)
    VZ SV6 A5
    Apr 2010
    Roleystone, Perth
    Default New Rotors (Is There A Running In Period?)
    Hey guys,
    Ive just got new some new rotors for my VZ, went down the DBA 4000 Slotted road with Ultimates, Is there a running in with new rotors?
    I need to start a thread for my 3yr Club Spec VZ SV6
    Cheers,
    Matty
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    there is a bedding in proceedure you should perform to ensure good braking and minimise rotor warping. DBA should list the bedding in proceedure. it mainly consists of maintain speed of say 60kph then braking to 10kph then repeating say 3 times then repeating the whole proceedure at 80kph then 100kph, but it does vary between manufactures
    VX Senator 300
    Oct 2005
    The 'gul, Vic.
    Pretty much on the money, although, I'd try around 6 x 60kph - 10kph applications - DO NOT STOP COMPLETELY.
    Then, 6 x 80kph - 10kph applications - again, do not stop.
    Then, 2 x 100kph to 40kph.
    Use a firm, smooth brake application, do not jump on them.
    And then, you're done. Ensure you allow for a bit of cooling between stops.
    cheers
    Senator 300 - the CLASSY C4B!
    LS1 - ETP215 @ 62cc, Comp 215/223 .602/.609 @111+3, 8.050" P/R, Morel link-bar lifters, Powerbond 25% UDP, 36lb injectors, SLP pump, Rollmaster timing chain, OTRCAI, T-56 - RipShift, 3.91:1 rear, DiFilippo 1.75" 4-1s St/St HPC coated, DiFilippo twin 3" st/st cat-back, 3" metal substrate hi-flow cats. AP-Racing 6/4-pots. EFIlive COS3 SD tune. 308RWKW. My ride:-http://www.cardomain.com/ride/389253...lden-commodore
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    i know with the rda rotors, i had to apply heavy braking from 60-10km/h 8-10 times, where as soon as i got to 10km/h, i had to accelerate to 60, then brake again. felt a bit like a douche doing it down the street with people watching me, they prob thought "what a wank thinking hes driving a v8 supercar" lol because thats pretty much what u have to do, like when they warm up. there should also be instructions with the brake pads, some manufacturers say just to drive normally for 1000km but without braking heavily, and only small braking
    Spoken by a true member of The Committee
    GSXR1000
    Apr 2010
    WA
    Vz Sv6 04
    Nov 2009
    Bundaberg
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Rubbish... I whack mine in and go for it.. Normal driving 'beds' them in...
    Life starts at 200km/h
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    not really, there is a correct way.. if you get the rotors hot then stop for a period of time, the pad contact on the rotors traps the heat in that one spot causing hotspots, which in time can lead to warping.
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    WTF??? How does that make sense, the pads and rotors are designed to dicipate heat, besides, unless you got your foot on the brake pedal, they shouldn't be touch the rotor anyway. And for them to warp, I assume this would have to occur for a number of days constantly...
    We are not talking about v8 super car brakes here, these are the ordinary ones fitted to most stock commodores. They should nit get got enough to warp any rotors.. Average driving, normal circumstances, I'm sure the brakes cool down fairly quickly, otherwise they would suffer brake fade and u would see a lot more commodores falling off the side of hills and cliffs
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    oh ok calm down people!~
    lets see hear back to basics \
    i fitted new pads? = yes
    do i need to brake easy for 100km's or so = yes
    do i avoid HEAVY BRAKING = yes
    there we go
    just fit them right,
    take it easy for a week
    and DONT wash them out hot and you wont have any problems with slotted rotors
    oh fyi slotted brake rotors disapate brake fade AND dust build up causing glazing
    drilled and slotted greatly improve on above
    my vt got brake fade at a 150km/hr to dead stop application of brakes
    dont know how many of you are braking that heavy?
  1. exhaust settle in period
    By park0 in forum V6 Development And Modification
    Last Post: 12-05-2009, 05:00 PM
  2. Rebuilt 5L 308 Run in period?
    By al's vn ss in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-05-2009, 09:31 PM
  3. never chose a good drive behaviour period
    By cxcxcxvcvcvc in forum The Pub
    Last Post: 13-03-2007, 11:42 AM
  4. Rego Lapsed, Grace Period.
    By mwethereld in forum The Pub
    Last Post: 06-12-2005, 11:28 PM
