Results 1 to 5 of 5
Thread: VZ 05 wont cank over...ecu, bcm, sensors? PLZ HELP
    253 hilux
    Jan 2011
    brisbane
    Default VZ 05 wont cank over...ecu, bcm, sensors? PLZ HELP
    Hey guys i have read through other threads on here to try sorting out my issue but each one is a little different to my situation so thought id list the specifics.
    Its an 05 VZ as stated (auto), last night we went to go out for dinner and it wouldnt start. Just ticking at the stater motor no cranking. It was first claiming an ABS fault, then later, low fuel, service and SRS airbags. i have checked terminals, battery, starter wires and reset the ecu. since reseting, the ignition wont even turn on so i cant even system check to get an error. Has anyone experienced this before please help!!
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Dead battery... Replace it you should be fine. Ticking at the starter motors usually tells me this
    Life starts at 200km/h
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    all the faults appearing also tells a dead battery. my battery went and said abs fault a week before it died
    Spoken by a true member of The Committee
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    +1 dead battery
    the abs module doesnt have enough voltage to wake up and so sets codes in ipc "abs fault"
    light goes out if jump start if battery fault as altenator takes over the supply job of voltage
    else worst case scenario intermittant no clicking and no start is earth inside ECM needing new engine control module
    replace battery check if any lights on then repost here!~
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    I can get batteries for $40
  1. VT 5.7L Oxy Sensors
    By ROBBO_308 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-01-2011, 07:36 AM
  2. VS V6 O2 sensors??????????????
    By pando666 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-07-2009, 08:21 PM
  3. VT sensors
    By joel448 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-05-2009, 10:32 PM
  4. what do i do with sensors with air pod in
    By crainy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-08-2005, 08:58 PM
