Results 1 to 6 of 6
Thread: Vz ss
    03 vy calais L67
    Moto X Champion!
    Mar 2009
    Townsville, QLD
    Default Vz ss
    im looking at buying a VZ SS ute or sedan 6spd manual. whats a list of problems/things i should be looking out for when inspecting the vehicle? apart from the obvious like tyres, clutch travel, oil leaks etc.
    03 vy calais L67
    Moto X Champion!
    Mar 2009
    Townsville, QLD
    wikky is offline ............
    VZ SSZ
    Mar 2008
    Here
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    VZs are pretty good, just clocked up 156,000kms in my 5.7 6spd.
    No oil leaks, original clutch (amazingly) still goes as hard as it did with half the kms.. And I dont drive it like a nanna, it gets a hiding on every outing.
    All Ive had to replace is the water pump which was when it was still under warranty and rebuilt the diff because the bearings were getting noisy and bad backlash. Other than that the usual stuff like shockies, brakes etc.. Engine is unopened, gearbox still humming along nicely..
    Silver Certified.
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    ^^^ Understand that my car has been meticulously maintained though with all fluids being changed on a regular basis and everything getting a thorough check over every 5000kms retensioning bolts etc
    So a car that hasnt been looked after wont be the same..
    Silver Certified.
    vz ss 6.0 l76
    Jan 2011
    shepparton
    look at the bloke your buying it off...that will tell you a lot about the car
