Results 1 to 9 of 9
Thread: Check Powertrain After Installing Manifold Insulators.
    VZ SV6 A5
    Apr 2010
    Roleystone, Perth
    Default Check Powertrain After Installing Manifold Insulators.
    I installed Mace manifold insulators this arvo. Job went smoothly.
    Headed home via the servo, Car is running fine, no lights or warnings yet. Then heading home from the servo I get Check Powertrain Msg. The car still runs fine with no issues just the powertrain light.
    Now first question:
    Would this be related to the Insulators? Filling up at the servo?
    Any thoughts?
    Cheers,
    2006 VZ commodore Acclaim
    Jan 2007
    Ipswich QLD :(
    Have you left something unplugged by accident ? Bumped something out of place ? Just go through and make sure everything is plugged in properly. ( as the obvious answer )
    If not it may just a coincident and something else has failed. ( like I got that warning after driving though a puddle of water, Turned out to be the Oil pressure sender. )
    Vz Sv6 04
    Nov 2009
    Bundaberg
    i just did mine and went for abit of a drive and havent had any problems yet man
    VZ SV6 A5
    Apr 2010
    Roleystone, Perth
    Went through and checked everything, Going to get it scanned today to fint the problem. Hopefully I have missed something and its just a quick fix.
    ashbox's Avatar
    ashbox is offline 6 speed
    VZ SS 6 Spd
    Apr 2007
    The Car
    05 VZ S COMMODORE UTE
    Jan 2011
    Old Toongabbie
    sp001in's Avatar
    sp001in is offline vyma100
    MALOO R6
    Jul 2005
    QLD
    I have heard the MACE throttle body can some times set off a fault code on the powertrain due to throttle positioning and heaps of other factors. but manifold spacers are a first.
    make sure you post up the cause of your problem once you find out what it is
    Check out my build <---Click me
    Now sporting ASR audio interior lighting and stereo mods, and MACE induction mods.
    Need your computer tuned, or dash calibrated??? Want your PS3 fixed, or wish to prevent the YLOD?
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    Quote Originally Posted by VZ_commo91 View Post
    Most likely tats all it would be! As long as u weren't having any issues before hand.
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    VZ SV6 A5
    Apr 2010
    Roleystone, Perth
    Found the issue to be a cracked PCV hose at the rear near the barometric sensor, It was cracked beforehand but didnt open up until I removed the Plenum. The Intake has got fuel consumption down to 10L/100km combined which is awesome.
  1. Installing Manifold Insulators
    By miner_richie in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 22-09-2010, 04:01 AM
  2. Manifold Insulators - What are they?
    By Maccas90 in forum Mace Engineering
    Last Post: 19-07-2010, 09:34 AM
  3. DIY Manifold Insulators?
    By sweefu in forum V6 Development And Modification
    Last Post: 27-02-2010, 02:13 PM
  4. MACE CAI Manifold Insulators ???
    By mattakaspeeedy in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-02-2010, 09:45 AM
  5. manifold insulators
    By Archers in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-05-2009, 09:58 AM
