Results 1 to 12 of 12
Thread: Rear Passenger Door Lock Issue
    VZ Executive
    Dec 2008
    Default Rear Passenger Door Lock Issue
    The Rear Passanger Door will not unlock. The Little Door indicator and rod is able to be pulled out and I am unable to remove the door trim as the door is locked. Any ideas?
    Couldn't be without my Commodore
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    remove the inside door handle and see if it is actually clipping onto the latch to unlock the door, if its not, or its broken, just grab a pair of pliers and pull the latch so it unlocks from the inside
    Spoken by a true member of The Committee
    VZ Executive
    Dec 2008
    Thanks for the reply! If the latch is broken how do I replace it? And once I open the Door that way how do I re-lock it?
    May 2009
    Gold Coast
    i dunno lol, if it opens, remove the door trim and investigate it further, see if its repairable or if the lock mechanism needs replacing. thats the only way i would know how to open it, but someone else may know of other ways to do it
    VZ Executive
    Dec 2008
    Seems to all we working fine, and if anything, I would assume the door would / should still lock and unlock regardless of the little Door Indicator -Roddy thing. Anyone else able to assist?
    VZ Acclaim
    Jan 2010
    Brisbane,QLD
    VZ Executive
    Dec 2008
    No, The Child Lock is not on! The Door indicator thing has come out of the door with a small rod attached to it....
    VZ Executive
    Dec 2008
    I can't open it from inside or outside, anyone know what to do?
    JShaw's Avatar
    JShaw is offline greeeeeeeeen
    06 VZ Executive
    Dec 2010
    South East Melbourne
    wow thats rooted! my driver door wouldnt open because the lock wouldnt pop all the way up when i unlocked it, but it doesnt do it anymore :S haha hope you find an answer man!
    VZ Executive
    Dec 2008
    Anyone have a picture or a diagram of the inside the door so I can try and work out how to put it back in?
    Little Red VZ Go-Kart's Avatar
    Little Red VZ Go-Kart is offline Middle-age mutant ninja
    Ex-CFA VZ 175 Commodore Exec. 06 wagon
    Aug 2010
    Democratic People's Republic of Highton / Geelong
    He said the "The Door indicator thing has come out of the door with a small rod attached to it....", so this to me suggests the issue is a bit more serious than first considered i.e. it's broken further down and/or the rod has disengaged from the locking mechanism. The solution is to remove the inside door trim (it is screwed on in several places around the perimeter) to expose the innards. Record what you do so that the screws and snap-pins all go into the same position. The inside of a door on a VZ is a bit intimidating on first appearance.
    The orange clip securing the door lock knob is not really re-useable and a new assembly (knob + clip) should be obtained from Holden to ensure a solid fit.
    If a door lock knob periodically does not unlock or lock, it indicates a problem with the solenoid e.g. worn out (sh*t happens...). Same thing as earlier mentioned: remove door trim completely to replace and you're ready to boogie.
    •:*¨¨*:•.When you start your car, does it return the favour? •:*¨¨*:•.
    Originally posted by soop
    Your arse is going to sting for a while, and then worse when it does bugger all.
    VZ Executive
    Dec 2008
    Thanks, But I can't open the door to remove the trim! And If I was to do anything dodgy to open the door through the handle hole I won't be able to re-lock the door, and Holden are shut for the day :/ I kinda think that the rod has just slipped off.. So if anyone has a picture of how the rod goes back in would be much appreciated!
  1. Help! rear passenger door stuck in dead lock
    By darkclaw in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-08-2011, 11:16 PM
  2. Passenger Door Lock-Out
    By Holdfast in forum VL Holden Commodore (1986 - 1988)
    Last Post: 29-05-2010, 07:41 PM
  3. Passenger door lock siezing
    By Ramsey82 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 14-02-2010, 02:49 PM
  4. ignition/steering lock problems passenger door lock
    By timbuk3 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 06-02-2010, 08:21 PM
  5. Broken passenger door lock
    By VRFURY in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-04-2006, 03:01 PM
