Results 1 to 13 of 13
Thread: Rough idle Alloytec
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
    Question Rough idle Alloytec
    Fella's.
    Heard a rattling sound coming from the engine the other day. Popped the hood during idle and removed the left bank cover. The sound was coming from the Purge Control solenoid. My understanding was this is not supposed to work at idle? Can anybody shed some light on the conditions it is supposed to operate? Tested it last night and it seems to be working fine. Thinking it may have something to do with the rough idle I experience from time to time.
    Your thoughts please.
    VZ Exec Wagon MY06
    Aug 2008
    Cairns
    I have the same problem but would discribe the noise a ticking.
    If you hold it you can feel it chattering away.
    Will post a vid tomorrow.
    2006 VZ ute
    Sep 2010
    all it does is vents out the charcoal canister. if this was to operate at idle the engine would get extra fuel and air. this would quite possibly cause a rough idle. an idea when it does idle rough unplug it and see what happens if it smooths out or not. but keep in mind it will throw an engine light.
    VZ A4 Saloon
    Nov 2010
    Would like to try and disconnect. But I've got to catch it first. Thats the problem.
    Shanen. Have you made that videos yet?
    VZ Exec Wagon MY06
    Aug 2008
    Cairns
    VZ A4 Saloon
    Nov 2010
    Thanks for that. Exactly same as mine. Gave it a tap and it stopped. Could be getting jammed? May try a replacement.
    Sent Holden Customer service an email about the problem last week. Got a voicemail from them yesterday wanting me to call them back. Great I thought. Might have some info on the problem. Rang them today quoting their reference number. Quoted number to the rep, put on hold.....finally replys later with, please consult your Holden Service Technical Advisor on your issue. What a waste of time! Would have been easy to say that on the voicemail.
    VZ A4 Saloon
    Nov 2010
    Spoke to a Holden Technical Guru today. He says it is normal for the PCS to operate during idle.
    VZ Exec Wagon MY06
    Aug 2008
    Cairns
    Ok... Nothing to worry about then?
    VZ A4 Saloon
    Nov 2010
    Little Red VZ Go-Kart's Avatar
    Little Red VZ Go-Kart is offline Middle-age mutant ninja
    Ex-CFA VZ 175 Commodore Exec. 06 wagon
    Aug 2010
    Democratic People's Republic of Highton / Geelong
    Quote Originally Posted by heyitsEnricoPallazzo View Post
    Looks that way. He also said rough idle on the Alloytec is normal. Bah.
    Bullshit. "Normal" when it is caused by something requires servicing/replacement.
    The PCS is feeding miniscule amounts of vapour into the engine all the time and by this action it does not cause rough idle. For all that can be said, what about a dirty MAFS? Cold engine? Too many short trips? Spark plugs? Dirty injectors? Unserviceable fuel filter? A slight bump now and then does not qualified a "rough idle".
    •:*¨¨*:•.When you start your car, does it return the favour? •:*¨¨*:•.
    Originally posted by soop
    Your arse is going to sting for a while, and then worse when it does bugger all.
    vz acclaim
    May 2011
    sydney
    hey, just wondering if u worked out what the problem was my car makes the same noise
    VL Calais Manual, VZ SV6 Manual
    May 2011
    that same thing ticks in my car... but its not constant like that... say if i give it a little rev once my foot leaves the pedal and the revs start to drop it will click once... happens everytime i give it a little rev!
    VZ A4 Saloon
    Nov 2010
    Solenoid pulsing at idle makes a fast ticking sound. Sounds like dodgy injectors.
    I still maintain it should not operate at idle!
  1. V6 VT rough idle - still
    By DeanoNSW in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-10-2011, 08:34 AM
  2. Rough idle, Rough take off and rough stop.
    By Niggadore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2010, 05:49 PM
  3. Vz alloytec rough idle
    By mattscuda in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 15-04-2010, 12:03 AM
  4. Rough Idle???????
    By m3taL in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-09-2006, 08:10 AM
  5. vn rough idle
    By Garth in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-09-2004, 08:34 PM
Tags for this Thread
