Results 1 to 6 of 6
Thread: Alloytec Engine Removal
    VZ
    Oct 2010
    Default Alloytec Engine Removal
    what are the best points for lifting the motor out?
    I currently have the auto gearbox attached. Is it best to lift the lot or remove the gearbox separately?
    2006 VZ commodore Acclaim
    Jan 2007
    Ipswich QLD :(
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Quote Originally Posted by VZ_commo91 View Post
    Lift the lot out. Much easier IMO.
    so you have done it before?
    Life starts at 200km/h
    VZ
    Oct 2010
    Default Engine Out
    Update.
    There are two M10 bolt bosses at the front left (looking from the front of the car) and two at the back right. I manufactured a couple of plates, bolted them in and connected to an Engine leveller with chain and D shackles. I lifted the engine and gearbox out without many problems. The hardest part was getting the gearbox past the steering rack. I had a floor jack under the end of the gearbox and as I lifted the engine, I raised the rear of the gearbox. It was a bit touch and go with tight clearance at the top rear of the motor. In the end, it was not real hard, only messy. Fluids everywhere.
    Glenn
    4 wheels
    Mar 2011
    in a house
    Keep box in vehicle, drop motor/steering rack, by using a hoist lift the vehicle, only takes a day to do this and swap motors.
    Jan 2007
    Ipswich QLD :(
    Quote Originally Posted by impulsive View Post
    Yes. I have pulled out many RWD engines, and find it an ass load easier to take the lot out.
    But then also No, I have never taken the ALLOYTEC out.
    Not to mention if you just take the engine out, you have to struggle to get the torque converter back on to the box. recently changed a 4l60E with the motor still in, and it was a absolute bitch.
  1. VZ alloytec v6 belt tensioner removal
    By v6rick in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 07-05-2012, 03:58 PM
  2. Alloytec spark plug removal
    By BobT in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 19-05-2011, 11:55 PM
  3. V6 alloytec engine top covers - removal of
    By LaoK in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 07-08-2005, 10:29 AM
  4. Alloytec and Alloytec 190 Engine Specs and Details
    By Gobbles in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-06-2005, 05:24 PM
  5. Alloytec spark plug removal
    Last Post: 14-05-2005, 10:00 PM
