Results 1 to 3 of 3
Thread: 2007 VZ Wagon Fuel flap
    2007 Vz Wagon
    Jan 2011
    Central Coast
    Default 2007 VZ Wagon Fuel flap
    Hi, I just sanpped my fuel flap off today and cant afford to buy a new one for $70 what the best way to fix it and what should i use...thanks
    Little Red VZ Go-Kart's Avatar
    Little Red VZ Go-Kart is offline Middle-age mutant ninja
    Ex-CFA VZ 175 Commodore Exec. 06 wagon
    Aug 2010
    Democratic People's Republic of Highton / Geelong
    You can get a replacement (unpainted) VZ wagon or sedan fuel filler flap from holmart in Victoria.
    HOLTS AutoColour spray paint matched to your car's colour for another $14 or so and you're in business.
    Link to holmart: Commodore VZ (scroll down a little over half-way down page).
    Otherwise, wreckers, but you'd still need to strip the paint and respray — unless such small details do not matter...
    •:*จจ*:•.When you start your car, does it return the favour? •:*จจ*:•.
    Originally posted by soop
    Your arse is going to sting for a while, and then worse when it does bugger all.
    VZ 2005 Executive Wagon
    Sep 2009
    Northern suburbs of Adelaide
    Quote Originally Posted by Percylamb View Post
    Hi, I just snapped my fuel flap off today and cant afford to buy a new one for $70 what the best way to fix it and what should i use...thanks
    I snapped mine off about 12 months ago. Fortunately, it snapped off cleanly, where the hinge attached to the inside of the actual flap itself.
    What I did was clean up the area affected by the break with turps then metho, and then ensuring to check that the two parts would match up perfectly at the break, I used Superglue to temporarily attach the two pieces together. I then used high strength Araldite to fill the entire cavity adjacent to the break, to build up the area next to the break. Worked a treat, however the high strength Araldite takes a couple of days to cure, so while it is curing, you have to be careful that the flap is positioned so the Araldite doesn't run out of the area you want it. The attached pic shows where I applied the Araldite (the yellowy brown patch on the flap/hinge area).
    With the high strength Araldite now holding the bits together, next time I'm an idiot and accidentally try to break off the flap, I'll probably do more damage to the attaching vehicle panel itself.
    Hope this helps.
    Attached Thumbnails Attached Thumbnails 2007 VZ Wagon Fuel flap-fuel-flap-repair-resized-480x640-.jpg
  1. vt fuel cover flap , where to get one cheap
    By banga in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-02-2010, 08:19 PM
  2. Fixing broken fuel flap
    By adamc11 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 31-03-2009, 12:00 PM
  3. VN fuel flap
    By potshots007 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-08-2005, 08:08 PM
