Results 1 to 6 of 6
Thread: vz thud sound when goin at walking pace, what is it?
    vs wgn series 2 v6 5sp getrag,vz wgn auto dual/f
    Dec 2007
    nthn suburbs, vic
    Default vz thud sound when goin at walking pace, what is it?
    got a vz wagon on duel fuel automatic exec, when ur stuck in traffic and stopped with ur foot on the brake and then u release the brake and start rolling at walking pace, it makes a thud sound as tho im running over those little square reflectors on the rd, it is constant until i start accelarating, it just goes thud,thud,thud like the kind of thing as if u had some rubber hanging off a tyre and smacking on the guard with each rotation.
    it sounds like it is coming from the transmission.
    Little Red VZ Go-Kart's Avatar
    Little Red VZ Go-Kart is offline Middle-age mutant ninja
    Ex-CFA VZ 175 Commodore Exec. 06 wagon
    Aug 2010
    Democratic People's Republic of Highton / Geelong
    My VZ wagon also thuds briefly when starting off at slow pace. The Holden Service Manager, who I had spoken to on unrelated matters, is aware of it — so too, many other owners; IIRC, something to do with differential / axle and considered normal.
    •:*จจ*:•.When you start your car, does it return the favour? •:*จจ*:•.
    Originally posted by soop
    Your arse is going to sting for a while, and then worse when it does bugger all.
    VH SL/E, Chevy Luv, VN S Pack
    Jun 2006
    my vn commodore made a similar noise, turns out it was the tail shaft uni... just a thought.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The IRS Commodores have a habit of wearing the diff mount bush, the diff clunks up and down when it is worn and it sounds like someone is under the car and thumps the floor.
    Visit my Facebook page
    Dec 2007
    nthn suburbs, vic
    Quote Originally Posted by Not_An_Abba_Fan View Post
    thanx mate, i hear that noise u descibed but it comes from under the console area betwwen the front seats, is that where i should hear it, or from the back, sounds can be hard to pinpoint i suppose.
    popped my head under, and are u talking about the big "u" shaped thing on the rear of the diff housing? is the bush easy to change?
    also the rear wheels are wearing on the outside.
    Aug 2010
    The thud comes from the rear.
    To say it comes from the console up the front is truly alarming. Just what is it that is going thud under there??
    Visible wear on the outside of the rear wheels is an alignment problem (unless you're running donuts on only two side wheels!?). Camber is out (wheels pointing out rather than in). I think thrust alignment corrects out-of-line camber. It would have to be a pretty marked misalignment for wear to be visible.
  1. VZ Commodore 4Spd Auto Thud Sound
    By extremeaudiowa in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 09-09-2010, 01:41 PM
  2. Replies: 7
    Last Post: 07-07-2010, 07:34 PM
  3. Space Walking
    By brownie82 in forum The Pub
    Last Post: 11-07-2006, 03:02 AM
  4. Walking the Dog
    By kowan in forum Jokes/Humour
    Last Post: 18-06-2006, 01:01 AM
