Results 1 to 14 of 14
Thread: vz idles rough and misses when aircon turned on
    vs wgn series 2 v6 5sp getrag,vz wgn auto dual/f
    Dec 2007
    nthn suburbs, vic
    Default vz idles rough and misses when aircon turned on
    it vibrates the car and every 10 secs or so it has a bad miss then continues idling crap again, its fine when ur driving along tho.
    and when aircon is off it idles fine.
    ive replaced plugs and all 4 o2 sensors about 8 mths ago but its been havin this prob for ages. it hesitates during takeoff under med-heavy accelaration so im thinking coils could be suspect.
    vz hesitates during takeoff. coils???
    hi all under med to heavy accelaration i can feel the car hesitating heaps, but only when taking off from the lights. at speed when u floor it it isnt noticeable. ive changed sparkplugs and all 4 o2 sensors, its got 133k on it so maybe coils im thinking. but also some one on here said something about gas vapour filters needing replacement every 20k and lpg computer recalibration ev 12 mths. what are ur thoughts?
    got a vz wagon on duel fuel automatic exec, when ur stuck in traffic and stopped with ur foot on the brake and then u release the brake and start rolling at walking pace, it makes a thud sound as tho im running over those little square reflectors on the rd, it is constant until i start accelarating, it just goes thud,thud,thud like the kind of thing as if u had some rubber hanging off a tyre and smacking on the guard with each rotation.
    it sounds like it is coming from the transmission.
    Last edited by mattyr82; 30-01-2011 at 03:42 PM. Reason: thread police says too many threads, it costs him $$$ ev time multiples are made
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    Check the charge voltage.
    $20 your alternator is dying. Mine is at the moment too and it does the same thing.
    When you turn the car on, hold the two buttons under the mode button down and it will take you into a small diagnostic mode on the dash. If you click mode you can scroll through to the Voltage, it should be about 14.2vlt while the car is running. Anything under 13.5 and you're in trouble.
    *Mine gets down to 10volts when I have the AC, head lights and stereo on.
    Dec 2007
    nthn suburbs, vic
    i tried it and went right thru mode and it doesnt give a voltage option? only lots of other acc changing options, digital speedo, auto volume/ radio display, lights on when exiting/entering the car etc.
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    hold the mode and set buttons when car is off, and then turn ket to acc, will bring up the diagnostics, then u can start the car and they should still be showing
    Spoken by a true member of The Committee
    Dec 2007
    nthn suburbs, vic
    Quote Originally Posted by soop View Post
    it was 13.8-9 with a/c and radio. did get down to 12.8-9 with a/c,radio,hazards,h/beams and brake lights on.
    so sitting in it in the driveway it doesnt seem to do it when its on petrol, then switch back to gas,wait few secs for it to pump thru and starts stuttering again. maybe gas isnt tuned to cope with extra load at idle of having a/c on but missus claims it stutters up steep hills and around some roundabouts also but i havnt witnessed this yet, but im hardly in it as its her car.
    Quote Originally Posted by richardpalinkas View Post
    thanks this worked.
    MY06 VZ SV6 A5
    Jan 2011
    Campbelltown, NSW
    Oh god things I have got to look forward to with my VZ....... -.-'' All new Kia Optima does look pretty good, time for an upgrade anyone? Haha....
    Dec 2007
    nthn suburbs, vic
    Quote Originally Posted by Commy SV6 View Post
    yes mate pure joy lol. toyotas looking good.
    Dec 2007
    nthn suburbs, vic
    but seriously any one got any ideas? or even a good lpg place that can do the lpg maintenance i mentioned in op.
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
    bludeck's Avatar
    bludeck is offline Wishlist = Blowa
    VZ Wagz
    Dec 2007
    Gold Coast
    matty my vz is doing the same thing again, and its not on gas, started turning the ac off at lights its that annoying.
    When it started it the mechanics couldnt figure it out and switched a coil lead i think or coil, and didnt do it for about 10thou kms.
    Due for another service and i think new coils are on the cards, everything else has been checked.
    Let uno how it goes, u made any progress??
    VZ
    Jan 2011
    VZ holden SV8 VT SS VN Calais all current rides
    Mar 2009
    baldivis wa
    Dec 2007
    nthn suburbs, vic
    Quote Originally Posted by bludeck View Post
    hey mate, after changing the plugs and o2 sensors and every other serviceable component.....changed all 6 coils myself off of ebay, and voila problem solved!!
    did notice that 1 coil was newer and had previously been changed, dont see the point in this, might as well change em all and be done with it! im going to book it in at a lpg place, he's gonna hook it up to the lappy and check all fuel trims and replace the gas vapour filter soon. let us know how u go also.
    bludeck's Avatar
    VZ Wagz
    Dec 2007
    Gold Coast
    Got a service today, ie plugs, oil, coolant flush. and yeah the problems gone(for now) which is wierd as the plugs wernt that bad and for a problem like that to come back you would suspect coils.
    Once the miss returns, coils are definatly next item to replace.
  1. Rough idle, Rough take off and rough stop.
    By Niggadore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2010, 05:49 PM
  2. Starts , runs nice , then Idles high , misses and coughs , then just stops........
    By Gus The Snail in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-06-2010, 10:25 PM
  3. vs v6 idles rough & rich
    By livingwreck in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-02-2008, 10:39 PM
  4. VN idles rough won't Rev
    By aries75au in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-01-2008, 06:53 PM
  5. temp at half way if aircon turned off
    By muzza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 10:44 PM
