vz alloytec accelerating problems
danryan
esperance
vs calais vz berlina
hey guys just wondering if anybody has had any problems with their vz alloytec not running clean thru the rev range under heavy accelerating ? almost like pinging under load.
greenacc
Searching for the billion
VE Berlina
how many k's ?
Any other symptoms like rough idle ?
danryan
esperance
105 thousand
slight rattle first thing in the morning.
has the usual miss at idle i believe thats
normal though.
danryan
esperance
been thinking about it for
a while and remembered that i put injector
cleaner through it about 2000km ago. and it
didn't have a problem before then.
danryan
esperance
I had a full inspection from dempster holden esperance on it when i first bought it,
they said it was a normal for it have a slight miss at idle occasionally especially with the first of the alloytecs.
mattsv6
VZ SENATOR
It's either your spark plugs or coils.
Had the exact same issue at almost the same K's.
danryan
esperance
i will pick up some new spark plugs for it tommorow.
process of elimination i guess
