Results 1 to 20 of 20
Thread: vz alloytec accelerating problems
    vs calais vz berlina
    Nov 2010
    esperance
    Default vz alloytec accelerating problems
    hey guys just wondering if anybody has had any problems with their vz alloytec not running clean thru the rev range under heavy accelerating ? almost like pinging under load.
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Nov 2010
    esperance
    105 thousand
    slight rattle first thing in the morning.
    has the usual miss at idle i believe thats
    normal though.
    Nov 2010
    esperance
    been thinking about it for
    a while and remembered that i put injector
    cleaner through it about 2000km ago. and it
    didn't have a problem before then.
    keeny's Avatar
    keeny is offline keeny
    vz calais alloytec 190
    Dec 2008
    Maitland, NSW
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    not normal to have a miss at idle lol as said id be checking spark plugs, maybe coils? and run a few tanks of 98 if you dont use that alrdy
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    Nov 2010
    esperance
    I had a full inspection from dempster holden esperance on it when i first bought it,
    they said it was a normal for it have a slight miss at idle occasionally especially with the first of the alloytecs.
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    VZ SENATOR
    Mar 2009
    It's either your spark plugs or coils.
    Had the exact same issue at almost the same K's.
    Nov 2010
    esperance
    i will pick up some new spark plugs for it tommorow.
    process of elimination i guess
    keeny's Avatar
    Dec 2008
    Maitland, NSW
    you could always just pull out the three plugs that are easy to get to and have a look at them... it could very well be one of your coils aswell, finding out which one will be process of elimination.
    Little Red VZ Go-Kart's Avatar
    Little Red VZ Go-Kart is offline Middle-age mutant ninja
    Ex-CFA VZ 175 Commodore Exec. 06 wagon
    Aug 2010
    Democratic People's Republic of Highton / Geelong
    Quote Originally Posted by keeny View Post
    you could always just pull out the three plugs that are easy to get to and have a look at them... it could very well be one of your coils as well, finding out which one will be process of elimination.
    If it is a coil a corresponding Trouble Code would be shown; no code = no glitch with coil(s).
    •:*¨¨*:•.When you start your car, does it return the favour? •:*¨¨*:•.
    Originally posted by soop
    Your arse is going to sting for a while, and then worse when it does bugger all.
    greenacc's Avatar
    VE Berlina
    Jul 2008
    Um which 3 plugs are easy to get to ? I though the manifold had to be removed to get to any of them ?
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
  15. #15
    Nov 2010
    esperance
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    As others have said id be getting a new set and changing them, and yes you have to remove the manifold to get to any of them
  17. #17
    Aug 2010
    Plugs last anywhere between 100,000 and 120,000km if the correct plugs for Alloytec engines were specified (platinum).
    Do you have any idea at all when they may have been installed?
  18. #18
    greenacc's Avatar
    VE Berlina
    Jul 2008
  19. #19
    keeny's Avatar
    Dec 2008
    Maitland, NSW
    you can definantly remove both back ones and i think the middle drivers side plug by just removing the engine covers. the coils are held in with one bolt each about 10mm head then with a little bit of force they pop out. its easier if you can remove the input plug first. i had a faulty coil and there were no error codes until the diagnostics machine was plugged in, pin pointed misfire in the exact cylinder. since plugs were new just got new coil and fixed the problem instantly.
  20. #20
    Jaydenvz is offline White knuckle fever
    Vz excecutive ute
    Feb 2011
    Gold Coast
    I had a similar problem with mine but it was due to the cats well at least one of them being stuffed I had a slight vw bettleish sound to it between 1200 - 2000rpm don't know if this is what you are experiencing mine had only done 55000ks but I bought it new and have driven it pretty hard
  1. Problems accelerating from standing start
    By sircruisealotVS in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 12-11-2010, 04:26 PM
  2. Alloytec Owners: Who has the best sounding alloytec?
    By Owned in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-07-2010, 01:19 AM
  3. vz alloytec extractor/high flow cat problems
    By create a storm in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-10-2008, 07:01 PM
  4. Accelerating (RPM)
    By AttaBoy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-06-2005, 11:21 AM
  5. Alloytec and Alloytec 190 Engine Specs and Details
    By Gobbles in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-06-2005, 05:24 PM
