Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Thread: VZ SV6 Spark Plugs? better performance?
    VZ SV6
    Feb 2011
    Question VZ SV6 Spark Plugs? better performance?
    Hey guys.
    Quick question, does putting better brand spark plugs in, such as platinum ones, increase the kw of your car? My mate seems to think for the price they are one of easiest way to increase the power of your car? Any thoughts on this and if so anyone know any good brands?
    Thanks
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Its been asked before. Your mate has been struck by the placebo effect. Its all BS, the fuel either burns or it doesn't.
    2005 VZ Acclaim
    Jul 2009
    Northern Beaches, Sydney.
    Sort of a hi-jack
    but how much is the usual cost for replacement of spark plugs and surrounding servicing?
    D22 St-r Navara
    Dec 2010
    perth
    im under the impression there are already iridums in there. you have to remove the intake manifold top to change the plugs on the alloy tech
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    not sure on the alloytecs, but with the ls1 i was reading in a magazine, they changed simple things like the airfilter, tested, spark plags, tested and spark leads and tested and found that each had a gain of somewhat, i think around 15kw or something just by doing it, but then again, who knows the condition of the original parts replaced
    Spoken by a true member of The Committee
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    I changed the plugs n leads on ve ssv and not differnece in power, maybe a tad smoother running
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    CRUSTIN is offline P-plater
    VZ S 175 Ute
    Nov 2010
    Changing plugs and leads will give it a more powerful spark, but the timing of the spark is much more important, run ultimate, and get it tuned, if u can afford to run ultimate 24/7.
    '07 VZ Acclaim wagon.
    Sep 2010
    Mulgrave, VIC.
    The Alloytec engines have platinum/irridium plugs in there as standard anyway...
    "Crustin" and "WogBoyz" I don't quite understand how you can change the leads on a car which has coil-on-plug ignition.
    Need a part number? PM me.
    Luke.
    Escape-The-Fate's Avatar
    Escape-The-Fate is offline HSV, i just want one
    VE SS, M6
    Nov 2008
    Gold Coast
    Quote Originally Posted by Luke52 View Post
    not sure on the irridium, last time i went to buy plugs best i could get was platinum for the alloytec..was told irridium and alloytec dont mix
    Sticking a Chev badge on any Commodore is like putting a Nissan badge on a VL
    EOI....VE SS 18" wheels x4 with 5000k's on new tread, 2 of have very minimal gutter rash (previous owner) otherwise like new send me a pm if interested.
    Sep 2010
    Mulgrave, VIC.
    Yeah, wasn't sure which it was. Regardless, platinum and irridium are both considered "performance" plugs. However I am very sceptical of any actual performance difference. The only reason I'd ever buy precious metal plugs would be purely for the life of the plug, especially in an engine like the Alloytec where changing plugs isn't quite as simple as most or if they were a standard application in that model.
    Luke.
    2004 VZ Calais 190Kw
    Dec 2009
    Penrith NSW
    Genuine Holden plugs are just re-badged Bosch Platinums.
    Last lot I got were $7.70 @ but when you only have to change them every 120,000Kms it isn't a big price to pay.
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Let me help you understand
    azazeldeath's Avatar
    azazeldeath is offline Donating Member
    VZ Holden Crewman 06 6sp S pack
    Oct 2010
    Darwin, NT
    2 things, richard; did they run new plugs, airfilter and the likes for the base and then gain the power? If not the results are invalid.
    2nd even the LS1 runs coil packs, I have heard of performance coil packs but converting the engine to run spark plugs would decrease performance and probably cost you a small fortune since it would have to be custom made
    Feb 2007
    Firstly, the Alloytec (GM HFV6) engines have coil ON plug ignition and therefore have NO leads as the coils sit right on top of each spark plug. The L76, L98, etc. V8 engines have coil NEAR plug ignition and therefore have leads connecting each coil to the appropriate plug.
    The Alloytec engines are specified with Bosch platinum spark plugs as standard. These are the best spark plugs for this particular engine as they put the ignition system under the least strain as the plugs wear. In practice, iridium plugs do not last quite as long as the platinum plugs (part5icularly double or quad-platinums) under most applications, especially if you're running the engine on LPG.
    Injected CNG, LNG & LPG: The only way to go better!
  15. #15
    VZ S 175 Ute
    Nov 2010
    Luke, when I said Leads, i mean as an example. Ive done a bit of work on the intake, so i knew about 'COPI' before that post.
  16. #16
    Sep 2010
    Mulgrave, VIC.
    Quote Originally Posted by WogBoyz View Post
    I stand corrected. I was almost certain they had coil-on-plug ignition.
    Quote Originally Posted by CRUSTIN View Post
    Er, right.
    Luke.
  17. #17
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    The more expensive plugs simply have a longer life and need to be changed less often.
    Any performance gains would simply be due to the original items wearing out and not operating at 100%.
    Silver Certified.
  18. #18
    Feb 2007
    Just get the Bosch platinum plugs direct from Holden. They last the distance and are good value compared to the iridiums, plus they're the recommended plug for the engine.
  19. #19
    VZ S 175 Ute
    Nov 2010
    Er, right.
    That's the V8 fool. Notice the 4 leads on the side, and being a V, 4 on the other side. 4 + 4 is 8.
    We are talking about an alloytec 6 arnt we?
    Originally Posted by Little Red VZ Go-Kart
    1. Why would you want to floor it, or move it to the red line? Especially with the lack of airbags and ABS features!? What do you hope to achieve by that??
    Originally Posted by HoldenV8
    give everything a spray with wd40 wheels brakes that should fix the squeaks
  20. #20
    Sep 2010
    Mulgrave, VIC.
    It's a V8? NOOOO, REALLY?
    Thanks for the update, Einstein. WogBoyz mentioned the V8 engine, which I thought had COPI. I was however corrected.
    And yes, we WERE talking about the Alloytec motor prior to that, so I still don't understand why you mentioned changing the "leads" on one.
    Luke.
  21. #21
    VZ S 175 Ute
    Nov 2010
    Your so slow. I give up.
  22. #22
    Sep 2010
    Mulgrave, VIC.
    YOU'RE a moron.
    What you said is like saying "I changed the dizzy cap on my VZ and it ran better." It's a stupid example because the car in question doesn't even have the parts you mentioned replacing!
    Luke.
  23. #23
    '05 VZ SV8 Auto
    Feb 2011
    Bundy
    "Like sands through the hourglass, these are the days of our lives" Hehe sorry boys couldn't help that 1. Just to sidetrack a little, are the plugs on sv8's a hassle to replace as well? Never had a miss on the vy so wanna know what I'm in for (130 thou on the sv8 atm).
    "Such Is Life"
  24. #24
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Quote Originally Posted by Coaly69 View Post
    on my ve the back 2 plugs on either side were bitches to get out, and the front driver side one aswell, as the oil dipstick is right in the way
  25. #25
    '05 VZ SV8 Auto
    Feb 2011
    Bundy
    Humbug. Things were so much easier in the VH days. 2 hours to replace the old blue motor, now it's an hour to replace spark plugs lol. Also decent 2nd hand blue/black motors were $200, a tail shaft was $50 (Then another $50 cos the uni blew).
    "Such Is Life"
LinkBacks (?)
  1. 06-05-2012, 09:11 PM
  2. 27-02-2012, 02:46 PM
  3. 27-02-2012, 02:43 PM
  4. 12-01-2012, 12:27 AM
  5. 30-12-2011, 08:28 AM
  6. 25-11-2011, 05:46 PM
  7. 07-08-2011, 10:26 PM
  8. 17-06-2011, 03:33 PM
  9. 12-05-2011, 11:44 AM
  10. 28-04-2011, 07:16 PM
  11. 13-03-2011, 10:56 PM
  12. 01-03-2011, 02:53 PM
  1. Replies: 25
    Last Post: 05-02-2011, 07:52 PM
  2. Spark plugs
    By Northern_Union in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-02-2010, 02:55 PM
  3. High Performance Spark Plugs in a VX 3.8?
    By entourage88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-09-2009, 09:58 PM
  4. Performance spark plugs worth it??
    By matt089 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-07-2009, 04:14 PM
  5. Spark Plug Leads Getting 'baked' on to Spark Plugs?
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2005, 04:16 PM
