Results 1 to 7 of 7
Thread: vz exhaust rubbers
    Ray De Man's Avatar
    Ray De Man is offline Donating Member
    HBD VZ SV6
    Feb 2009
    Melbourne, Vic
    Question vz exhaust rubbers
    I've done a search but only comes up with older models.
    Hi guys, as title suggests, how do I remove the two rear muffler figure of 8 rubbers? They have some sort of stopper on the end off two brackets. I've sprayed then with WD40 and they started to twist (by hand) but then grinded to a stop. It's not a nut so can't use a spanner, it looks like it has two tabs on sides but I can't get them off!
    Could someone please advise me on best method on getting these off? I have too much robble at rear and it's sitting too low. Old rubbers cracking and very stretched.
    Thanks in advance.
    '07 VZ Acclaim wagon.
    Sep 2010
    Mulgrave, VIC.
    I tried some long-nosed pliers to bend the tabs, then slide them off, but that didn't succeed for me. I then just got a flat-head screwdriver, jammed it underneath the tabs and bent them upwards, which allowed them to slide straight off.
    Need a part number? PM me.
    Luke.
    Ray De Man's Avatar
    HBD VZ SV6
    Feb 2009
    Melbourne, Vic
    Cheers for the quick response.
    Ok so force is needed to get them off? But once the tab/stopper is forced off, how do you get it back on? As that is in place to stop the rubbers from sliding off the bracket...
    P.s You live near me...
    Sep 2010
    Mulgrave, VIC.
    I do believe I just used the pliers again to force 'em back on.
    And if that's the case, send me a PM if you want me to pop over and lend a hand.
    Luke.
    Sep 2010
    Mulgrave, VIC.
    In fact, I think I have some of my old rubbers which I replaced with a different style when I did my exhaust. They're still in good nick, and you can have them if it saves you a few bucks buying new ones.
    Luke.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The tabs on the clips lock into the groove on the hanger. Bend the tabs up so the clip is loose, then just slide it off.
    To put them back on, bend the tabs back down a bit then push them over the hanger until the tabs click into the grooves again.
    Visit my Facebook page
    Ray De Man's Avatar
    HBD VZ SV6
    Feb 2009
    Melbourne, Vic
    Cheers Not_An_Abba_Fan for that useful information, will have a go.
  1. How to remove rear exhaust rubbers?
    By hsvboy1978 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-01-2011, 01:01 AM
  2. Strut rubbers
    By vt_lover in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-12-2007, 06:46 PM
  3. How to know if you need new suspension rubbers
    By Wingnut0021 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-03-2006, 07:10 PM
  4. Door Rubbers
    By wooly72 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-11-2005, 10:28 AM
  5. Door Rubbers
    Last Post: 22-11-2004, 08:25 PM
