Results 1 to 8 of 8
Thread: engine cuts out while driving
    vz executive
    Feb 2011
    victoria
    Exclamation engine cuts out while driving
    i have a 2006 vz exec wagon auto, i have had this car for just over a year now and had nothing but problems. first was the car wouldn't start, took it to the mechanics 10 times, only till i threaten them i'll go to consumer affairs things go done. now the car is stalling while driving and i have to go back to the same mechanics due to warranty.
    the problem is that its a random thing, but it seems to happen when i apply the brakes. also the abs warning light comes on quite often.
    i told the mechanics about the car cutting out and the abs light, and they say that they reset the abs system, and that is it
    any help please
    please someone help
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
    Is it on LPG?
    What condition the battery? Common for ABS to fault when battery volts are low. Have it load tested if in doubt.
    Over to you.
    vz executive
    Feb 2011
    victoria
    no it doesn't run on lpg, i always fill up with 91 unleaded.
    the battery is less then 6 months old, but i have had my haven't suspicions about it though. i'll go and get it load tested now
    2006 VZ commodore Acclaim
    Jan 2007
    Ipswich QLD :(
    Alternator ? If you have a scan gauge, it should be between 13.7 and 14.2 V I'm pretty sure.
    vz executive
    Feb 2011
    victoria
    just had the battery tested, the battery is is all good, though it needs a charge. the car charges the battery fine.
    also i just put the car in diagnostics mode while car is running, and stated:
    switch voltage 5v
    battery voltage 13.9v
    i also know that there are a few other vz's that are doing the same thing
    Little Red VZ Go-Kart's Avatar
    Little Red VZ Go-Kart is offline Middle-age mutant ninja
    Ex-CFA VZ 175 Commodore Exec. 06 wagon
    Aug 2010
    Democratic People's Republic of Highton / Geelong
    Well it's not a common problem among VZs. Cars stalling while being driven are extremely dangerous and should not be on the road: a serious fault exists somewhere, possibly with the speed sensor / ABS controller module. A trouble code should be logged if it is a component someplace, and these codes can be found through the ACC-ON diagnostic method (don't start engine, just to ACC-ON with mode-set keys held).
    Switch voltage and battery voltage as you recorded are both normal. Your mechanics need to interrogate the ECU more thoroughly than to just "reset the ABS".
    •:*¨¨*:•.When you start your car, does it return the favour? •:*¨¨*:•.
    Originally posted by soop
    Your arse is going to sting for a while, and then worse when it does bugger all.
    vz executive
    Feb 2011
    victoria
    i totally agree that it is extremely dangerous and should not be on the road, that is why I'm trying to fix it.
    the mechanics that i have been going to are useless, specially since they are a Holden dealer/mechanics, and I only go to them to keep the warranty. it's like there not taking it serious. is there any good mechanics that can fix this issue?
    Aug 2010
    If you have a gripe with Holden or Holden's technicians, then take it up with Holden's office at Port Melbourne. If there is a problem with Holden's dealers, I'm sure they (HO) will be receptive and look at the details, especially since you appear to be saying that Holden is not taking it seriously and by association, putting your safety at risk. You could of course take the car to any other mechanic/dealer, but in doing so with the car under warranty, it could well be voided by that act of personal convenience. Your call.
  1. HELP!!! VN cuts out while driving.
    By paulisdead in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-12-2010, 04:37 PM
  2. VT Engine cuts out while driving...
    By EnzyG in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-08-2009, 04:48 PM
  3. Cuts out mid driving
    By Skeletroopa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-05-2009, 12:26 PM
  4. vl engine cuts out when driving. HELP IM STUCK
    By blue_vl in forum Electrical Wiring / Questions
    Last Post: 06-02-2009, 04:10 PM
  5. Engine cuts whilst driving.
    By BR377 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-09-2005, 02:59 PM
