Results 1 to 8 of 8
Thread: Has anyone elses vz v6 developed a ticking noise after oil change??
    vz equipe 3.6
    Sep 2007
    gold coast
    Default Has anyone elses vz v6 developed a ticking noise after oil change??
    Hi guys i have a tick from drivers side and sure its a lifter,only happened when the oil was changed so put some lifter free in it before xmas and its still apparent,Any ideas how much to fix the lifter thanks
    aj1987's Avatar
    aj1987 is offline 05 VZ Calais
    '05 VZ Calais
    Jun 2010
    Central Victoria
    Hmm, mine was doing it too, but was 3k over due for a service, after the service, no more noise.
    VZ Calais + 690 KTM = Happiest bloke on earth.
    '07 VZ Acclaim wagon.
    Sep 2010
    Mulgrave, VIC.
    What oil did you use?
    I've heard from many people that Magnatec can cause ticking noises like that. It sure did for mine..
    Need a part number? PM me.
    Luke.
    vz equipe 3.6
    Sep 2007
    gold coast
    thanks guys.got it serviced at auto leaders and they use valvoline semi synthetic.Took it back to them and they put in the nulon lifter free.My vs had the same tick so not too worried at this stage as its not getting any worse but im thinking about giving the motor a flush using an additive then putting penrite in it
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
    Changing the oil is a good place to start.
    Personally I wouldn't use a oil flush additive. They have been known to make oil seals weep. But given your engine is relatively new, you should be OK.
    Little Red VZ Go-Kart's Avatar
    Little Red VZ Go-Kart is offline Middle-age mutant ninja
    Ex-CFA VZ 175 Commodore Exec. 06 wagon
    Aug 2010
    Democratic People's Republic of Highton / Geelong
    You might also want to check the purge control solenoid left side of engine (passenger side) at idle; a loud ticking/tapping is not a normal condition but can be isolated as cause of ticking by removing plastic cover and listening/feeling solenoid when engine idled, and again when engine speed is increased. A loud, rapid ticking/tapping favours scrutiny; a soft ticking is normal.
    •:*¨¨*:•.When you start your car, does it return the favour? •:*¨¨*:•.
    Originally posted by soop
    Your arse is going to sting for a while, and then worse when it does bugger all.
    06Calais's Avatar
    06Calais is offline Keeps me Broke
    06 calais
    Apr 2011
    Australia
    can the purge thingi cause bad fuel economy if its not working, also can it cause power loss if its ticking and not working properly. Mine does tick a fair bit, but it may be unrelated but I have also lost maybe 10 to 15% power and have slightly worse fuel economy too.
    WL CAPRICE
    Mar 2011
    Quote Originally Posted by 06Calais View Post
    Anyone got an answer to this?
    It also relates to my car.
  1. ticking noise
    By mike4226 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 06-12-2010, 06:23 PM
  2. Ticking noise
    By Cameron P in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-07-2010, 05:53 PM
  3. ticking noise in L67....
    By emmtee83 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-11-2009, 05:45 PM
  4. ticking noise..
    By matt_gotigers in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-11-2007, 09:44 PM
  5. ticking noise
    By krisjanik in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-09-2006, 06:44 PM
