Hey
good news I got the radiator cap off by using rubber gloves which gave me extra grip
bad news opened Radiator cap and creamy glug comes out... its almost solid [ engine overheats too]
could that be a closed shut thermostat?
or cracked head gasket? cracked head?
not alot of bubbles in there but its creammy crap coming out
thanks for any help anyone can give me![]()
Sounds like you have a ####ed headgasket
Originally Posted by garth
Yah, seriously fugged head gasket.
+1...........................
yep headgasket for sure ..
^^ Absolutely.
Oil and water = gloop that you are seeing.
Bubbles when engine is at idle is also a reliable indicator of head gasket gone.
Head is routinely examined for cracks when gasket is renewed. These often show up when surfaces are very thoroughly cleaned.
•:*¨¨*:•.When you start your car, does it return the favour?•:*¨¨*:•.
Originally posted by soop
Your arse is going to sting for a while, and then worse when it does bugger all.![]()
