Hey guys I am looking at a 05 VZ wagon. But there appears to be a fault with the immobilizer. it leaves the drivers indicator on. you have to lock and unlock it several times to get the indicator to to turn off. (it leaves indicator on constantly it does not flash while on). but when the indicator isnt stuck on it will work fine.
Could this be an easy fix. Relay flasher can etc or is it more serious?
Has anyone else come accross this problem.
forgot to add. the immobilizer works regardless off whether indicator is lit or not. It still locks and unlocks starts fine etc.
Sounds like you might have the dreaded 'stuck relay' problem. PM me, as I may be able to help with a replacement relay if required.
Also check this thread, to see if your problem is the same.
How to fix the sticky indicator in a VZ Commodore (BCM)
