Results 1 to 5 of 5
Thread: I need help Guys
    VZ Exec
    Feb 2011
    Condong NSW
    Default I need help Guys
    I got the info from this site some days ago re: resetting the computer display when you have completed the service on the VZ. But it did not work all the way. I held down the up and down arrows turn off the ignition etc etc I got the screen to reset but when I hit the set button it does not reset..I tried this formula several times but it would not reset. Do I need to complete any other service..I changed oil and filter, checked all fluids. drained radiator and run some flush thru it and drained and refilled. check all levels. Can anyone help me out there...Regards Annie
    Zeussy's Avatar
    Zeussy is offline SSM11K
    VY Acclaim S2, VH SLE
    Dec 2008
    Central Coast
    Do what you were doing to get to the screen that says "reset service reminder" or something like that, then hold the set button for like 3 seconds, til it goes beepdidlybeep, then turn your ignition off, and hey presto!
    Should work. Maybe. It might.
    And, probably post in the right section, this is the wrong section
    Little Red VZ Go-Kart's Avatar
    Little Red VZ Go-Kart is offline Middle-age mutant ninja
    Ex-CFA VZ 175 Commodore Exec. 06 wagon
    Aug 2010
    Democratic People's Republic of Highton / Geelong
    Annie, get your guns out!
    Print this out and take it with you to the car, then follow carefully.
    1. Turn the ignition off.
    2. Hold down the trip computer UP and DOWN buttons together.
    3. Turn the ignition ON while still holding down both buttons.
    4. After approx 3 seconds, release both buttons.
    5. The service menu appears and asks if you want to reset.
    6. Press and hold the SET button for more than 3 secs.
    7. Press the MODE button.
    8. Turn ignition OFF.
    "Service reset no items" or similar should display on the screen after this procedure.
    Do not confuse this with the more pointed "Service Vehicle Soon" or SVS indicator: this means that engine requires an unscheduled service somewhere, usually with a corresponding Trouble or Fault Code.
    •:*¨¨*:•.When you start your car, does it return the favour? •:*¨¨*:•.
    Originally posted by soop
    Your arse is going to sting for a while, and then worse when it does bugger all.
    2006 VZ commodore Acclaim
    Jan 2007
    Ipswich QLD :(
    LOL 'till it goes beepdidlybeep' guess thats the noise it makes :P
    But yeah, what he said ^^^
    Zeussy's Avatar
    Dec 2008
    Central Coast
    Quote Originally Posted by VZ_commo91 View Post
    Thats exactly the noise it makes, man, talking to a chick here? Thats how I'd talk to my sister so she'd understand (no offence Annie )
    Quit stalking me...
  1. hi guys
    By procar towing in forum The Pub
    Last Post: 04-01-2010, 01:05 PM
  2. You Guys Got A New One.!
    By qaiz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 02-03-2009, 04:32 PM
  3. what do u guys think
    By VryNeat in forum General
    Last Post: 10-09-2008, 04:38 PM
  4. What is it with guys???
    By tara1 in forum The Pub
    Last Post: 02-09-2008, 08:33 PM
  5. VS V8 what do you guys think of them
    By CHANDLC in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-06-2006, 02:29 PM
