Results 1 to 11 of 11
Thread: Need help please
    tHe_sTiG's Avatar
    tHe_sTiG is offline <--- Want a ride?
    VZ Executive
    Jan 2010
    Saudi Arabia
    Angry Need help please
    My VZ's got a problem Here's how it goes:
    Started up the car this morning and got the "Service Vehicle Soon" screen, along with some very rough idling. Turned off the car and turned it back on again, then all was fine, drove off.
    This afternoon, turned her on and the "Service Vehicle Soon" came up again. Ignored it, drove off. As I was driving, another screen came up: "Safety Mode" followed by "Reduced Performance". Throttle was limited, could crawl along at no more than 45 km/h.
    When stopped at the lights, the car idles at about 1200 rpm.
    This isn't the first time this happens. When it did, took her to Holden, got a new oxygen sensor. No improvement. Took her back, updated software, done. That was about a year ago.
    What could the problem be this time?
    The only Exec in Saudi that's now properly badged!
    2DIE's Avatar
    2DIE is offline ONEDOLLAHOLLA
    97 Acclaim
    Feb 2008
    South Aus
    Is it due for a service? No idea about the VZ but you can reset the service reminder manually.
    As for safety mode and reduced performance I have never seen that.
    If everything else is in good working order it could possibly be a faulty ECU?
    Best RPG ever
    tHe_sTiG's Avatar
    VZ Executive
    Jan 2010
    Saudi Arabia
    It's got just over 152,xxx and the next service is scheduled at 160,000 km. Last oil change was at 148,000; planning on doing the next at 153,000. What worries me is the way the car acts when the warnings come up: rough and very uneven idling, tacho needle fluctuates from 500 to 1200 rpm, causes the whole car to shudder violently.
    I don't see how the ECU is causing the problem here. The car is stock, nothing has ever been modifed in it mechanically.
    Here's what the owner's manual says:
    • Service vehicle soon
    If the 'Service Vehicle Soon' animation illuminates while driving, it indicates a non-emissions related fault in the engine management system or the automatic transmission.
    • Safety Mode
    If the 'Safety Mode' animation illuminates while driving, it indicates a fault in the electronic throttle control system. Although the vehicle may still be driveable, the throttle available may be limited, resulting in reduced power.
    Any idea what all these fancy terms mean? I'm taking it to Holden tomorrow to see what's wrong with it.
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    I'd bet money on the Service Vehicle Soon warning being there because your oil pressure switch is stuffed. A very common fault on Alloytecs, particularly in VZ's. Get a new switch fitted first. That will probably eliminate the SVS warning. Then see if they other warnings persist and have them diagnosed via the Tech 2 tool. Ultratune dealerships often have these and are far cheaper than your Holden dealer.
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Calaber is correct. Get the Oil Pressure Switch replaced and the warning will go away. It's the only way.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    tHe_sTiG's Avatar
    VZ Executive
    Jan 2010
    Saudi Arabia
    Just got the car back, problem appears to have been solved. The guys said a group of loose wires somewhere had triggered the warnings. I'll keep an eye on the car and see how it goes.
    2DIE's Avatar
    97 Acclaim
    Feb 2008
    South Aus
    tHe_sTiG's Avatar
    VZ Executive
    Jan 2010
    Saudi Arabia
    Hopefully that's the end of it. Are there any other problems I should be aware of concerning the VZ?
    VZ Exec Wagon MY06
    Aug 2008
    Cairns
    tHe_sTiG's Avatar
    VZ Executive
    Jan 2010
    Saudi Arabia
    VZ Exec Wagon MY06
    Aug 2008
    Cairns
    there are 6 of them and they are about $80.
