Results 1 to 6 of 6
Thread: List of problems
    tHe_sTiG's Avatar
    tHe_sTiG is offline <--- Want a ride?
    VZ Executive
    Jan 2010
    Saudi Arabia
    Default List of problems
    Can I have a list of problems / things that go wrong with the VZ? I've already replaced the O2 sensors and water pump, fixed a cracked radiater and oil cooler. Also did some software updates.
    The scale of the problems don't seem to matter. Whatever the problem, no matter how minor, the car will howl and cry and flash 'Service Vehicle Soon' at my face and restrict the electronic throttle. Picked it up from Holden yesterday after that happened, turned out it was only a few loose wires somewhere.
    The car here in the Middle East depreciates badly in value, won't be worth much at all if I sell it. I want to be ready for any more problems, and I want to know any steps / precautions I should take to prevent them from happening in the first place.
    VZ tonner
    Jan 2011
    the day i was supposed to pick up my VZ, a coil in the ignition barrel shit itself. had to get a replacement ignition barrel and new key machined. . . dunno how much it cost cos i didnt pay for it. This is apparently a common problem.
    wikky is offline ............
    VZ SSZ
    Mar 2008
    Here
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    the service vehcle soon message seems to appear when an oil pressure sensor is stuffed. replace that and it should fix the problem. if its not that, could be a near dead battery, my car displayed the abs fault and my battery died, common problem
    Spoken by a true member of The Committee
    VE Omega sedan 3.0 2010
    Feb 2011
    Fly Creek, N.T.
    Apparently the keys have a very fine tolerance, and so they don't have to wear very much before they won't rotate. I had to get new blades cut for my key, and a spare. I went to a locksmith to get this done, and so I retained the key head. The locksmith said that the system was good, but sensitive, and eventually it would wear out.
    Oil sensors seem to be a common fault.
    And, as I have recently discovered, the VZ doesn't like being left for a few weeks without being started - electrical problems are common, including "phantom messages" on the dash, and in my case, failure to start. Still looking for a long-term solution on that one.
    Little Red VZ Go-Kart's Avatar
    Little Red VZ Go-Kart is offline Middle-age mutant ninja
    Ex-CFA VZ 175 Commodore Exec. 06 wagon
    Aug 2010
    Democratic People's Republic of Highton / Geelong
    Oil sensors were a problem on GMs 3.8L V6 engines too. No car should be left weeks and weeks on end without use; I certainly wouldn't allow my VZ to sit idle for that long.
    Many problems come up because of people fiddling with the electronics (ECM, BCM, sensors and wiring) — problems not actually visible when the car is sold off to the next unsuspecting owner. So we need to be very careful tarring a good car with a problematic brush covered in feathers from previous users.
    •:*จจ*:•.When you start your car, does it return the favour? •:*จจ*:•.
    Originally posted by soop
    Your arse is going to sting for a while, and then worse when it does bugger all.
  1. VN and VP car wreckers list
    By dans_vz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-04-2012, 06:33 PM
  2. Wish-list for a better VE
    By Supe in forum VE Holden Commodore (2006 - ?)
    Last Post: 16-07-2008, 08:27 PM
  3. members list?
    By Troy711 in forum Site Feedback / Site Problems
    Last Post: 24-12-2005, 04:55 PM
