Results 1 to 5 of 5
Thread: vz battery terminal problems maybe
    VZ v6 Executive alloytech 04
    May 2010
    Default vz battery terminal problems maybe
    hi all...started car the other day just clicked than lost all display and power,noticed negative terminal on battery was loose,its tight as tight can be and keeps slipping off causing not to start,bought universal terminals wont fit anyone had to change em? if so what types do u reccomend and is it a hard job to replace?
    cheers
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
    Is a correct battery installed? If yes go see a sparky. No probs with mine.
    vz exe.
    Nov 2010
    Vic.
    Why won't the new terminals fit? They can be gently prised apart a few mm if too tight or hammered tighter if too loose. Have a good look at the old ones first & see if something can be improvised, otherwise change to the new ones, easy job.
    vx s pack II
    Jan 2010
    aLKIDA
    Make sure you clean the terminals on the battery with a wire brush or battery terminal cleaner.
    For good connection.
    After you have installed the new terminals
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    or boiling water...
    Spoken by a true member of The Committee
  1. battery terminal problems
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-09-2009, 10:01 AM
  2. Replies: 7
    Last Post: 30-04-2009, 10:09 PM
  3. upgrading battery terminal
    By Denno in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-11-2008, 01:04 AM
  4. jaycar battery terminal question
    By roon_VR in forum Car Audio
    Last Post: 30-04-2008, 12:10 AM
  5. Battery Terminal Gold Plated Connectors
    By Bob129 in forum Car Audio
    Last Post: 06-11-2006, 06:13 AM
