Results 1 to 6 of 6
Thread: Reverse Parking Sensors
    2004 VYII S, 2005 VZ SV6
    Jan 2009
    Default Reverse Parking Sensors
    Hey guys, somehow ive come across a reverse parking sensor wiring loom from a S1 VY Calais, got bored today and checked out the boot of my car and it plugs into some connection in the left part of my boot (my sv6 didnt come with reverse sensors), so the question is can i just plug this straight into my car and then plug it up to those 4 sensors that go on the boot (which i have also)... Or is it just not that simple as it is in most cases, has anyone had any experience with this ??
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    If the loom has the beeper and module attached to it then it should just plug into the sensors and start beeping if you put your hand across one of the sensors.
    Not sure where the beeper is in my car as I have not gone looking for it but appears to be somewhere in the rear parcel shelf.
    Good luck could work out quite cheaply for you to have reverse sensors.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    Jan 2009
    Just tried that out, so i must be missing the module and beeper, might look around on ebay... Also rang up Holden and asked how much to install it, they reckon 3 hours @ $118 p/h, thats insane... I could probably DIY the holes in the bumper myself which was the main reason for the installation enquiry, but i doubt id do a decent job spacing them out
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Before you fit the sensors go and buy some painters masking tape (not just any masking tape as some will remove the paint).
    The good one is blue from memory and is design to come away without removing the paint.
    Anyway put a couple of strips of the tape around about the positions of the sensors and then meausre and mark your proper positions before drilling.
    Its alot easier to mark the postion on the tape than on you bumper paint.
    VZ Commodore Executive Wagon
    Apr 2011
    Frankston, VIC
    Did any VZ Exec Wagons come with reverse sensors? I put some after market ones in mine, but had a friend help me, who drilled the holes after we both marked them carefully, and now when you stand back from the car, the right hand side is higher than the left. I want to get a new bumper, with the sensors built in, so they are straight and look a million times better?
    Otherwise I'll just get a new bumper and drill them straight, or re-program my brain to get over it.. lol
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
    Quote Originally Posted by Adlikada View Post
    Don't believe wagons had OEM sensors.
    Perhaps try this product. No holes.
  1. Reverse Parking Sensors
    By luckycalais in forum VE Holden Commodore (2006 - ?)
    Last Post: 13-09-2009, 01:56 AM
  2. Reverse Parking Sensors
    By tigerpm7 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 12-04-2008, 08:45 AM
  3. Reverse parking sensors
    By shrapnel in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 16-05-2006, 11:46 PM
  4. Reverse parking sensors..
    By Shounak in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-08-2005, 07:05 PM
  5. Reverse Parking Sensors
    By Shounak in forum Electrical Wiring / Questions
    Last Post: 12-08-2005, 10:00 AM
