Results 1 to 18 of 18
Thread: vz commodore a horn under the bonnet Whats it for????
    vz commodore lumina
    Jan 2010
    sydney
    Default vz commodore a horn under the bonnet Whats it for????
    Hey people it seems theres a little horn on the Right side of the bonnet but i have NO idea what its for? its not the alarm, its not the cars horn ... WHAT IS IT???
    i have uploaded a pic if someone could tell me what it is and what it does it would be very helpful HAHA cheers
    Attached Thumbnails Attached Thumbnails vz commodore a horn under the bonnet Whats it for????-19022011944.jpg
    VU SS UTE / 5 Litre Volvo /Trusty Swift
    May 2008
    Penrith NSW
    The Picture has not loaded but if its at the rear of the engine bay on the passengers side its connected to your alarm set up..
    Why is it called Alcoholics Anonymous when the first thing you do is stand up and say, 'My name is Ray, and I am an alcoholic'?
    vz commodore lumina
    Jan 2010
    sydney
    Quote Originally Posted by DVOLVO View Post
    Yes that is the one, I tried locking the doors then opening it threw the window, Only the horn under the bonnet on the left side Sounds, this one doesnt sound anything?? what is it meant to do?
    Little Red VZ Go-Kart's Avatar
    Little Red VZ Go-Kart is offline Middle-age mutant ninja
    Ex-CFA VZ 175 Commodore Exec. 06 wagon
    Aug 2010
    Democratic People's Republic of Highton / Geelong
    If it doesn't beep-beep, maybe it isn't a horn............
    •:*¨¨*:•.When you start your car, does it return the favour? •:*¨¨*:•.
    Originally posted by soop
    Your arse is going to sting for a while, and then worse when it does bugger all.
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Yes it is part of the alarm system.
    Try disconnecting your front horns then open your car from the inside and see if the horn sounds.
    In my VS when the battery got low that horn started sounding continuously, drove me nuts until I put a new battery in.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    coasty's Avatar
    coasty is offline the voices told me to
    vz equipe & vt berlina both v6
    Feb 2008
    kanwal nsw
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    Ive heard its connected to the alarm but yes, it never seems to make sound.
    I'd try disconnecting the horns and see if it sounds. It'd make sense ... whats to stop someone just popping under the front bar and snip the wiring to the horn, so as they break in its silent? But if theres a backup horn up there, where its pretty much unaccessable, should they disable the main horns then the cars still gonna make a noise
    '05 VZ SV8 Auto
    Feb 2011
    Bundy
    Is it the door lock one? Set trip comp to indicator + horn when locking and have a peek cos that sounds different to the horn and the alarm in my vz and vy.
    "Such Is Life"
    2004 VZ SV6
    Jan 2011
    Newcastle, NSW
    I have no noise nor indicators when locking/unlocking my car, but my horn sounds if i open my door (my normal horn), i also have no dash options for changing ANYTHING on the trip computer (there is no 'trip computer' or similar in the menu
    '05 VZ SV8 Auto
    Feb 2011
    Bundy
    Quote Originally Posted by morphix View Post
    Hmm strange, so you have tried pressing the up/down arrows when prompted after turning the key on? Should come up after "System Check" message. No need to start the car just turn ignition on until you see battery light then wait for the prompt.
    Thought you could only set the lock option to Horn + Indicators or just Indicators. Could be wrong but I'll check when I pick up my sv8 this arvo. As for the horn when opening the door...Anyone else?
    "Such Is Life"
    2004 VZ SV6
    Jan 2011
    Newcastle, NSW
    Yep, tried doing that both when just turning the ignition, also when turning the car on, same thing there is nothing in the menu in relation to Trip or Alarm
    It gets frustrating not having the options as usually when you lock/unlock commodores your lights will flash to indicate to locked or unlocked which mine does not.
    Makes an issue when leaving the car, i have to stand next to it and press lock to make sure it locks as if i move away i cant hear or see it lock.
    '05 VZ SV8 Auto
    Feb 2011
    Bundy
    That sucks mate, have you tried taking the + terminal off battery for 10 secs then replacing? Sucks not being able to muck with stuff like volume distortion limiter on the cd player and yeah,
    indicators on lock etc. If no-one else has an idea then it's off to Holden to burn some $ for labour costs to have diagnostics done.
    "Such Is Life"
    2004 VZ SV6
    Jan 2011
    Newcastle, NSW
    I have an aftermarket Head Unit, i've heard some options are stored in the original Head Unit, but surely not the Alarm and similar options?
    '05 VZ SV8 Auto
    Feb 2011
    Bundy
    Audio distortion limiter I'm unsure with aftermarked head units, I have my amp hooked up via the rear left door speaker with a line level converter (RCA to High-level input) to keep the steering wheel buttons and factory double din unit. Plus I hate the fascia unit for single din,
    never looks quite right. Sucks no mp3 but works well. Otherwise it's all down to the trip comp mate, not sure if the battery trick will reset it but worth a try if it annoys you that much. Personally I wouldn't stop tinkering till I fixed it or broke it lol.
    "Such Is Life"
  15. #15
    2004 VZ SV6
    Jan 2011
    Newcastle, NSW
    Yeah the Fascia colour is a bit off but the head unit i got goes nice with the dash plus it has mp3, aac support and usb.
    Due to idiot 'friends' wrecking my cds when lending to them ive ended up putting all mp cds onto the computer and not using my cds anymore. I put all the music i want in the car on my 16GB USB stick.
    At work at the moment will try the battery solution when i get home.
  16. #16
    '05 VZ SV8 Auto
    Feb 2011
    Bundy
    Yeah used the fascia in my vy, was ok but not ideal. After exhaust/tune etc looking at double din unit with wheel controls, dvd and sat nav. dunno how it will look though as the corners are slightly rounded so could be a gap. Good luck mate and let us know how ya go.
    "Such Is Life"
  17. #17
    2004 VZ SV6
    Jan 2011
    Newcastle, NSW
    The steering wheel control 'adaptor' to be able to use my head unit with them was $297, which i could not be bothered wasting that much money for.
    There are no gaps with my head unit and fascia but he colours looks off.
    Once i get more money together, i'd like to get a double DIN head unit aswell.
  18. #18
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
    Sounds like you need a late flash update from Holden.
  1. whats a 2nd hand bonnet worth
    By the_boozer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-12-2010, 06:16 PM
  2. commodore horn keeps stopping
    By vz23kq in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 11-10-2010, 05:31 PM
  3. How to change the horn in the 05 vz commodore
    Last Post: 19-09-2010, 03:30 PM
  4. help.. VC Commodore, Horn won't work
    By commodorian1 in forum Electrical Wiring / Questions
    Last Post: 25-06-2010, 09:48 PM
  5. how do you replace the horn in a VX SS commodore ?
    By chrisb in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-11-2004, 02:29 PM
Tags for this Thread
