Results 1 to 8 of 8
Thread: Knocking Sound From Front end
    eko's Avatar
    eko
    eko is offline 3kO
    Soon to own vb commy end of year
    Aug 2007
    South Eastern Suburbs
    Default Knocking Sound From Front end
    hey guys got my 06 vz exec when there was those minor floods few weeks ago drove through a puddle wasnt that deep thought after a few days later relised a sound from the front end when ever i full lock the wheel and drive usually does it when im goin over slightly bumpy roads i can hear a knocking sound coming from the front i was wondering if it was just a balll joints or bushes but wanted to make sure on what it actually was anyone have any idea thanks for the help
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    Sway bar links are common, as are lower control arm bushes.
    It could also be a knackered strut.
    How many Km's on it?
    Little Red VZ Go-Kart's Avatar
    Little Red VZ Go-Kart is offline Middle-age mutant ninja
    Ex-CFA VZ 175 Commodore Exec. 06 wagon
    Aug 2010
    Democratic People's Republic of Highton / Geelong
    Tie rod ends on front wheels connected to steering can knock, but generally they need to be struck quite hard by something to go out, or a bushing splits, thus introducing excessive play (there should be none). When they do go out, the wheel(s) are misaligned and abnormal wear will take place. Get under the front and examined the tie rod ends directly behind the wheels.
    •:*¨¨*:•.When you start your car, does it return the favour? •:*¨¨*:•.
    Originally posted by soop
    Your arse is going to sting for a while, and then worse when it does bugger all.
    eko's Avatar
    eko
    eko is offline 3kO
    Aug 2007
    umm wen i bought it nothing wrong wif it its on 93ooo ks now wat exactly happened was i went to beach at lakes entrance and ended up in a rocky bumpy sandy road and after i came bak sorta had slight sound than just grew bigger now wen i jus full lock it and drive on the grassy area in my driveway and its all bumpy just starts makiing that knocking sound
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Check the top nuts on the struts to make sure they are tight.
    Could also be your rack ends that are stuffed.
    Visit my Facebook page
    VZ Executive
    Feb 2010
    Mine had a knock in the front suspension.I removed the struts and springs cleaned out the stones and reassembled, problem fixed.
    eko's Avatar
    eko
    eko is offline 3kO
    Aug 2007
    ohh yehh i seee but mine only does it when u full lock and turn thats it nuffin on the straight nuffin over speed bumps its fine its only when i full lock and start turning
    eko's Avatar
    eko
    eko is offline 3kO
    Aug 2007
    thanx soop great help got it fixed all good was the sway bar links changed em over shes like a baby now thanx alot
    Quote Originally Posted by soop View Post
  1. Knocking Sound
    By chrism182 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-08-2011, 03:47 PM
  2. knocking sound when a/c is on
    By xeanerix20 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-11-2010, 11:14 PM
  3. knocking sound
    By viccib in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-12-2009, 03:52 PM
  4. knocking sound
    By Escape-The-Fate in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 13-05-2009, 12:01 AM
  5. Knocking Sound
    By davo2011 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-07-2005, 01:11 PM
