Results 1 to 14 of 14
Thread: Brake and Clutch Fluid Replacement
    impulsive's Avatar
    impulsive is online now Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Default Brake and Clutch Fluid Replacement
    Has anyone attempted an in house Fluid change on the above? My brake fluid is pretty shocking and needs replacement. I dare say it is as simple as drain, replace and bleed?
    Any suggestions?
    Life starts at 200km/h
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    A one-man brake bleeder kit is helpful, but no way as good as an assistant.
    Syringe most of the brake fluid out, top up with new stuff, and keep pumping the brake pedal (and topping up with new fluid) until new fluid comes out of all four corners. Never let the reservoir go close to dry of you will let air in the line which can ruin your day when driving.
    Ronald Reagan (1986)
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    VX Berlina
    Apr 2007
    That is brake, do you mean same for clutch? 'Cause I have no idea about clutches, all my car have been autos unfortunately
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    lol awesome.. does anyone know where the filler plug is for the 6 Speed Manual Transmission V6..
    VX Berlina
    Apr 2007
    Ok I just check my Gregory's manual. Yep same procedure. Syringe all old fluid, top up with new fluid, pump pedal a few times, open bleeder valve, keep pumping until only new fluid comes out and no air bubbles, close valve.
    With both brake and clutch ensure fluid level never drops below 75% or air may be introduced into the system.
    EDIT: Sorry can't help you with a VZ, regarding location.
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
    If you have an air compressor a vacuum bleeder is the only way to go, around $100. One man bleeders are rubbish.
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    When pumping the pedal the nipple needs to be open, when the pedal is coming back up it needs to be closed or it may draw air back on. (Hence being a two man job). ie open nipple push pedal to floor close allow pedal back up.
    Also start from left rear then right rear then left front then right front.
    Silver Certified.
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Do i need to bleed the brakes if i take less then 75% out of the brake resivior? Anyone know the capacity of the resivoir, ie how much fluid i would need for a complete change?
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Best to bleed regardless to get the old fluid out of the lines and calipers.
    Just suck all the fluid out of the reservouir and fill with new stuff. Bleed a corner, top it up, bleed a corner, top it up and so on.
    Silver Certified.
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Quote Originally Posted by RiCeY View Post
    Thats for the bleeding? it is safe to syringe the fluid out yes?
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    If you mean from the reservouir then yeah suck out as much as you can just dont let anyone touch the brake pedal when its empty.
    Silver Certified.
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    all done, both clutch and brake are working better..thanks for the help boys
  1. Clutch/brake fluid reservoir changeover??
    By Dale Mulej in forum VE Holden Commodore (2006 - ?)
    Last Post: 09-11-2010, 06:09 PM
  2. clutch fluid on pedal
    By todro in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-05-2008, 11:15 PM
  3. How to change clutch fluid
    By newtownbob in forum VY Holden Commodore (2002 - 2004)
    Last Post: 22-04-2008, 08:38 PM
  4. Changing Clutch Fluid
    By Johnny_V in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-06-2006, 08:27 PM
  5. Brake Fluid and Auto Trans Fluid.
    By Melchior3 in forum General
    Last Post: 20-02-2006, 11:49 AM
