Results 1 to 3 of 3
Thread: plastic strip peeling - how do i re-adhere it?
    vz
    Mar 2011
    Default plastic strip peeling - how do i re-adhere it?
    hi
    With every opening of the driver door the plastic strip is catching on the wheel arch panel and making a dreadful cracking sound. After each crack the strip is increasingly peeling away.
    how do i re-adhere the strip? is there a special kind of double sided tape i should be using? i also assume the existing adhesive would need to be cleaned right back with something.
    thank you
    VZ wagon
    Feb 2009
    Central Coast, NSW
    Did you sort out this problem? I just noticed that mine is starting to lift. I'm tossing up either re-sticking it and painting it to match the car or just taking it off.
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Sikaflex.........
    Silver Certified.
  1. Chrome strip plastic clips .
    By Fusion in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-09-2009, 09:04 PM
  2. [QLD] Headlining Plastic Strip (Rear Window) VN-VS Sedan
    By Hytes in forum Swap / Wanted to Buy / Trade
    Last Post: 27-04-2009, 12:28 AM
  3. Clear coat peeling and sticker peeling
    By And_ROOS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-11-2007, 07:41 PM
