Results 1 to 11 of 11
Thread: VZ D.R.L's (Help?)
    km5
    km5 is offline
    '06 Vz Executive
    Mar 2011
    Default VZ D.R.L's (Help?)
    Hey everyone,
    I'm new to this site and have just recently brought some drl's for my '06 Vz.
    Just wondering if anyone could PLS guide us through the installation process with pictures too if possible .
    I need to have them running during the day with h/lights off, and off at night with the h/lights on.
    cheers boys
    tim005's Avatar
    tim005 is offline Yet Another VS Ute Owner
    99' Series 3 VS S-Pac Ute.
    Feb 2009
    Melbourne.
    I can't help you specifically mate, but i am almost 100% certain this has been covered on here.
    Try the search button? I remember some bloke covering it step by step in a vy/vz.
    If not, i'm sure someone can lend a hand.
    http://forums.justcommodores.com.au/...first-car.html My VS Ute, 99', S Pac, 5 Speed.
    Quote Originally Posted by maldotcom2 View Post
    Also, always go into a corner in second gear in case you see a hot chick or another commodore you can fang it out sideways.
    km5
    km5 is offline
    '06 Vz Executive
    Mar 2011
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    Didn't it come with a wiring diagram??
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    km5
    km5 is offline
    '06 Vz Executive
    Mar 2011
    nah man no wiring diagram. Brought lights from ebay, only instuctions given were to wire positive to postive (great help).
    I've asked a sparky at work for some help and he's given me the rundown on it all, so hopefully I should be right
    Any other bits of info anyone can chip in would be greatly appreciated (Y)
    lein's Avatar
    lein is offline Comrade Commodore
    VZ Ute
    Dec 2010
    Tropical QLD
    Change over relay hooked to an accessories on circuit to power the lights whenever the key is to the acc/on position, and headlight circuit to turn them off as soon as they're turned on.
    Sounds like you've already got the good guff though.
    I aim to misbehave.
    km5
    km5 is offline
    '06 Vz Executive
    Mar 2011
    Oh thats not a bad way of doing it, I never heard of that way before...cheers mate
    What i'm planning to do though is use a 12v relay i brought from work:
    ** earth out the led lights to chassis, connect them to relay
    ** connect wire from fuse box that goes on with ignition to relay
    ** connect a wire to the relay from the headlight switch
    ** and then earth outt relay
    What use think??
    VY SS
    Jun 2006
    Albany
    yes that would work, just make sure the relay you have has an 87a terminal which the led's will need to go to
    km5
    km5 is offline
    '06 Vz Executive
    Mar 2011
    Vz Sv6 04
    Nov 2009
    Bundaberg
    when i installed mine i took the rubber stuff away from the positive and negative parker wires in the headlight then soldered the led wires onto them, so when i turn the lights on they come on with the parkers..
    probably a bad way to do it.. but it worked lol
    km5
    km5 is offline
    '06 Vz Executive
    Mar 2011
    Just wondering if anyone has ideas on how to install the strips without removing front bumper and what type of adhesive to use?
    cheers!
