Results 1 to 11 of 11
Thread: Lowering Rear only and keeping stock front Fe2
    SV6 P-Plater's Avatar
    SV6 P-Plater is offline Dont Speed In Surbubia
    VZ SV6
    Feb 2011
    Default Lowering Rear only and keeping stock front Fe2
    Hi guys,
    Might be a stupid question, i only want to lower the rear of my car as it sits too high, i like the stock height of Fe2 on the front as i sit nicely on car park gutters and my drive ways a B*** so is my works, and my main priority is handling im not after a cruiser im after something you can throw into a corner and expect a half good result, so lowering the rear is for mainly looks, i want the car too look lowered, and sit some what evenly
    i was thinking SSL's on the back with maybe pedders.
    will i need to change my shocks all round?
    can someone recommend some good products/set ups for what im after.
    cheers
    A bicycle
    Aug 2009
    Gippsland, Victoria
    SSL rears with fe2 fronts will not only look stupid, it will handle crap. it will give the car more understeer than it already has. will sit nose high.
    SL is really as low as you want to go without completely ruining your handling. it keeps the suspension geometry in 'around' where it was designed to be. it should be pretty much even in ride height, maybe a tad lower at the rear.
    remember, lower doesnt mean better handling.
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Quote Originally Posted by NonStick Squid View Post
    @old mate you drive a vs ute therefore you're a bogan therefore your point is invalid
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    VZ SV6
    Feb 2011
    Meant SL's no SS's sorry*
    Alright so it was a stupid question :P So as old mate is implying a different setup would be best suited, to achieve better handling.
    what about Sl's all round on a set of 19's with pedders shocks?
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    yeah mate, if you lower the rear on sl's might aswell do the fronts to suit... it wont lower the fronts much anyway!
    19's will look good with sl's
    Troy711's Avatar
    Troy711 is offline Moderator Puppeh
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    While you're at it ask the suspension shop to add massive camber on the rear to look like another busted arse P Platers heap of #### Commodore with a half arsed lowering job...
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
    If your looking at better handling. Save some decent coin and do it properly and professionally. Not peice-meal or half-arsed, like me!
    VX Exec M5
    Alien Invasion 2 Champion! Gyro Ball Champion!
    Apr 2010
    Melbourne, Bundoora
    My advice would be check out GSL Rallysport in the sponsor section
    and if you're serious about handling, whiteline sway bars FTW!
    None of us are as cruel as All of us. - Anonymous
    VZ SV6
    Feb 2011
    VZ SV6
    Sep 2010
    May I suggest coil overs? Much better handling and adjustable height (if you know how to do it that is). If you want better handling, coil overs are the way to go, that along with a strut bar, sway bar and some light wheels with good tires
    VZ SV6
    Sep 2010
    ohh! one more thing I forgot to mention. coil overs for VZ's cost about $1800 LOL
  1. lowering front without lowering rear.
    By pillzor in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-03-2011, 09:46 PM
  2. Stock 304 extractors worth keeping?
    By Mirkz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-02-2011, 09:23 PM
  3. Suspension advice, VS IRS lowering , front looks lower than rear
    By domtas in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2010, 09:32 AM
  4. Replies: 12
    Last Post: 31-03-2010, 07:03 PM
  5. Adding bass, but keeping the car stock
    By Lloyd1986 in forum Car Audio
    Last Post: 25-01-2007, 01:06 PM
