Yeh I bought one off the same mob............... had it about hmm a year now. Damn good, well worth the money. I fitted mine...... took bout 12 hours, alot of work. The LSD's are very tight for the first week or two when u first put it in......... then they wear in a bit and settle down but definately a good upgrade to any VZ.
Just gotta recalibrate your ECU for the new diff........... which is the biggest pain mostly as u gotta readjust your WOT shifts mostly...... eg. standard VZ can run upto around 72km in first gear, on these diffs at about 6400rpm (if u raise the limiter) they will only get to 66km/h in a 4 speed auto.
Hope that helps. Cheers
2009 VE SS SILVER SEDAN - Twin Amps... Tune in progress (more for response and power) then outright KW on a dyno
