Results 1 to 5 of 5
Thread: Air Con problem
    VZ Calais
    Mar 2011
    Glen Osmond
    Unhappy Air Con problem
    VZ Calais. On a hot day, the air conditioner blows cold air out of the demister section of the dashboard and not from the middle of the dashboard as directed by the controls. When there was not too much load on the engine such as going down hill, the air-con would behave it self for a short time and cool the car down as needed.
    The car has only done 50,000 klm, and I didn't expect a problem like this.
    Is any body else having this problem?
    Will the dash have to come out of the car to repair the problem?
    Richard
    lein's Avatar
    lein is offline Comrade Commodore
    VZ Ute
    Dec 2010
    Tropical QLD
    Sounds like vacuum. Either it was a long hill and that's just something that happens, or you might have a small vacuum leak to or from your vacuum ball.
    I aim to misbehave.
    VZ Berlina
    Jan 2009
    Maitland SA
    I have not had one Calais that didn't have this problem from vs to vz. Seems to be a common issue. But yeah check all hoses, etc. What I did on my vs was I actually cut into a line and created my own vac with a little pump. Solved the issue
    Join our Facebook Fan Page to Buy Sell or Trade your Cars/Parts Holden Auto Buy & Sell
    2006 VZ commodore Acclaim
    Jan 2007
    Ipswich QLD :(
    VZ 2005 Executive Wagon
    Sep 2009
    Northern suburbs of Adelaide
    Quote Originally Posted by VZ_commo91 View Post
    Thread about this not to long ago. Pretty sure it was vacuum.
    Sounds like the exact same problem I had with my VZ Executive. Both face & floor vacuum actuators were leaking, as well as the the vacuum mode selector switch. Replaced all three & the problem was solved.
    The only difference with the Calais, is the vacuum mode switch is replaced by a vacuum solenoid pack. A check on the entire vacuum system will need to be carried out, to determine where the vacuum leak is occuring.
    BTW, the default HVAC mode with a loss of vacuum is fresh/recirculation door positioned to fresh air, and the other actuators default position to the demist mode.
    The vacuum actuators can be replaced without removing the HVAC unit or the entire dash, however to access the rear actuator, you need to remove the centre console assembly, and the area under where the stereo headunit is located (well I did on mine anyway). It's not an impossible job to do, but just a bit labour intensive.
LinkBacks (?)
  1. 15-03-2011, 07:39 PM
  1. [VR-VS] How To: Fix the VS V6 4 Wire O2 sensor earth problem – Known Holden Problem
    By ephect in forum Holden Commodore How-To's
    Last Post: 17-01-2012, 11:25 PM
  2. VK v8 breathing problem/oil pressure problem
    By Bookanun in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-12-2010, 03:02 PM
  3. idle problem, very difficult to find problem
    By calais s2 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-07-2010, 10:51 PM
  4. Central locking Sv6 problem. this going to be a problem car??
    By philsv6 in forum VE Holden Commodore (2006 - ?)
    Last Post: 21-04-2010, 10:40 AM
  5. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
