Results 1 to 9 of 9
Thread: Air bag error code 101
    VZ Berlia
    Mar 2011
    Default Air bag error code 101
    i have an airbag code comming up. 101 - high restance found it right hand airbag. what would the problem most likely be? the clock spring i was thinking?
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
    Sure its P0101? Because P0101 is AFM fault. Or are you reading from dash cluster LCD?
    VZ Berlia
    Mar 2011
    no its comes up on the ultra scan as:
    101 - right hand side air bag has a high resistance
    im an appretice mechanic myself just dont want to start pulling things apart without some advice first. my best guess is that its the clock spring or a loose or dirty plug comming from it.
    VZ A4 Saloon
    Nov 2010
    VZ Berlia
    Mar 2011
    yes the SRS light is on. and the middle window in the cluster is flashing "airbag fault"
    VZ A4 Saloon
    Nov 2010
    VZ SV6
    Mar 2011
    Bunbury
    i noticed with mine, it started out as ABS fault every now and then, then graduated to Airbag Fault. was my battery. was had it. you maybe in the same boat not 100% sure mate.
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    and our Adventra had it, reset it, lasted 3 days then faulted again.
    We just took the airbag out, blew into the connectors and plugged it back in. This was August last year, no issues since. Weird!
    But yes, Ive heard low battery voltage will cause it too for some reason, VZs are particular about battery voltage
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Could be the clockspring or the airbag itself.
    You need to remove the airbag and plug in a dummy load, if the resistance doesnt change then the clockspring has failed.
    We have a special kit at work with dummy loads for different types of airbags, if you dont have access to something like this Im not sure how you would test this.
    More often than not it is the clockspring.
    Silver Certified.
  1. Error code 32 and 97
    By tropix100 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-11-2010, 05:53 PM
  2. error code 12, 3 times then code 76
    By muzza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-09-2010, 06:36 PM
  3. vx berlina traction and engine light come on intermittently/// error code error wtf
    By glennis in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-05-2010, 07:55 PM
  4. Error Code 75
    By ICUBYE in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-12-2006, 02:40 PM
  5. Code 14 what the hell is error code 14!@*&%#
    By Danzilla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2005, 12:35 PM
