Results 1 to 19 of 19
Thread: VZ v6/SV6 OTR CAI
    96 VS executive series II 'S pack'
    Jan 2011
    australia
    Default VZ v6/SV6 OTR CAI
    as there are not over the radiator cold air intakes for the vz v6, would it be possible to use an otrcai off either the V8 or any other otrcai as long as the piping for the throttle body has the same dimention/bolt pattern? or just use it how it is and make some custom piping off of the throttle body in place of factory intake piping. cheers
    98 VT s pac
    Sep 2009
    Hervey Bay, QLD
    can get a cai for sv6, look in right places or google... black sv6 ute on street commodores with a otr cai
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    link to this car? i personally have not yet seen one except for the ebay ones. the reason the otr will not work on the alloytec is because the maf is too close and because of laminar flow. google it if your not sure on what that means. che have tried to make one, but gave up the idea as it was too difficult to tune and because the gains with the cost of the otr didnt weigh up, best bet is to get whatever is on the market. either that or buy a motec and mafless tune your sv6 with an otr
    Spoken by a true member of The Committee
    Supercharged VU SS
    Feb 2006
    The Shire
    a mate at work has one on his vz sv6. so they do exist. but its not the nornal due to that maf sensor.
    basically it looks the same from the front but the hole out the back is off set to the passanger side, then it does a 90 degree bend to the maf sensor then another 90 degree bend inot the throttle body. sounds weird but still flow better then other set ups
    May 2009
    Gold Coast
    im guessing its an ebay otr? theyre the only ones i have seen with the maf attached to the throttle body at a 90 degree angle
    Supercharged VU SS
    Feb 2006
    The Shire
    2009 VE SS SILVER SEDAN
    Sep 2008
    Brisbane, Queensland
    OTR tunes do not work on these cars! OTR essentially requires proper removal of the MAF so your VE must be tuned to run the car without an air sensor. Thats the entire IDEA of MAFLESS OTR!
    Otherwise if you get a OTR with a dodgy mocked up MAF hold........... it needs ALOT of recalibrating of the MAF no matter what they say on eBay. Even things like MAF Reversion (when you take your foot off throttle) play a big role in this sort of POS.
    When you buy one and your car starts running like crap........... Then see if it's cool hey. Your better off going a 2-hole mod, mace cai kit or SS inductions. Otherwise if u really want a OTR, buy a V8 to put a proper one on.
    2009 VE SS SILVER SEDAN - Twin Amps... Tune in progress (more for response and power) then outright KW on a dyno
    Supercharged VU SS
    Feb 2006
    The Shire
    your a bit off the mark there mate... first of all there is no such this as a OTR tune. OTR means 'over the radiator', its just a type of intake. even with the v8s you dont need a mafless tune if the intake is setup up to take the maf sensor
    secondly it will not make the car run bad, the air sensor is still there and doing its job. it is simply removing the retriction of the air box and giving it a better placement for cooler free flowing air.
    Sep 2008
    actually naf your wrong. I'm 100% dead on the mark. OTR is 99.9% prefered mafless tune to go with it.......... and I know what it stands for you idiot. The maf sensor when moved around 'at all' need to essentially be re-calibrated on the ECU. It's not just some generic thing u can blow air on and it'll measure the same every time........ there's a bit more to it then that.
    ....... excuse me for thinking thats a numskull comment but sorry I know better........... OTR is not for the alloytech V6......... well not atleast the VZ series
    vz equipe 3.6
    Sep 2007
    gold coast
    ok so i dont know much about these otr.At the moment i have a k&n filter in my standard airbox really not much noticeable gains(just better throttle).My mate wants to help me do the 2 hole mod,but after seeing the one on ebay in a previous post makes me want to buy the otr.cars a v6 alloytech.What would be the best in terms of performance??
    Supercharged VU SS
    Feb 2006
    The Shire
    Quote Originally Posted by bigdaddycool View Post
    what are you basing this on?? i have seen it fitted first hand, and the car deffently ran nicer, no huge performance gains or miracle cures, but was just all round more drivable.
    no ones argueing that a maffles tune would be better, after all it is the weakest point in the intake system, but moving it 20cm closer to the thrttle body is not going to have an adverse effects. even on the v8 some choose to leave the maf sensor on when fitting a OTR intake, and still see power gains
    VZ V6
    Jan 2011
    NSW
    I fitted a OTR intake fitted on my VZ V6 using the air flow meter {just had to extend the wires} havent had any problems with idle/starting etc. Its alot more responsive, I may be selling it due to upgrading my car. PM me with an offer if anyones intrested.
    May 2009
    Gold Coast
    VZ V6
    Jan 2011
    NSW
    Default Vz v6 otr
    Sorry about the bad pic's, they were taken with the I phone.
    Attached Thumbnails Attached Thumbnails VZ v6/SV6 OTR CAI-photo-1.jpg   VZ v6/SV6 OTR CAI-photo.jpg
  15. #15
    May 2009
    Gold Coast
  16. #16
    May 2009
    Gold Coast
    thats from that OPG from ebay, they changed the design because they themselves said there was problems with the first lot
  17. #17
    CRUSTIN is offline P-plater
    VZ S 175 Ute
    Nov 2010
    Why even bother with an OTR? You might as well dust the car to remove weight. Spend your money on a real upgrade.
    Originally Posted by Little Red VZ Go-Kart
    1. Why would you want to floor it, or move it to the red line? Especially with the lack of airbags and ABS features!? What do you hope to achieve by that??
    Originally Posted by HoldenV8
    give everything a spray with wd40 wheels brakes that should fix the squeaks
  18. #18
    VZ S 175 Ute
    Nov 2010
    Oh and if you keep the MAF sensor, it may be too close to the entry of the intake(there is a reason why they put them in the middle of a straight pipe), there will be turbulence around the sensor and it will read wrong. Mafless if the way to go, if you can.
  19. #19
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Quote Originally Posted by CRUSTIN View Post
    such as...
    Life starts at 200km/h
