Results 1 to 14 of 14
Thread: vz v6 is still extremely sluggish
    VZ v6 Executive alloytech 04
    May 2010
    Default vz v6 is still extremely sluggish
    i posted this not long ago had a service done 2 times fuel filter and everything changed and checked and its still as sluggish as hell what could it be?
    also my wheels sound like a woot woot sound like a howling sound when im driving i thought i t was wheel bearing but machanic said no what could it be...starting to think my mechanic is really not as good as i thought!!!
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    If its not wheel bearings cheap tyres will make that noise. What brand tyres you running?
    As for being sluggish when did it start?
    Silver Certified.
    VZ Berlina
    Jan 2009
    Maitland SA
    Sluggish and Sounds are two different things.
    So is it Sluggish
    and there is a sound coming from the front end?
    Sluggish, throttle body? does it feel like u put ur foot down and dont get the reaction u were hoping?
    Woot Woot, umm i would say tyres too.
    Join our Facebook Fan Page to Buy Sell or Trade your Cars/Parts Holden Auto Buy & Sell
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
    If everything has been 'changed and checked' and your still not happy. I'd give your mechanic the flick and go elsewhere.
    2009 VE SS SILVER SEDAN
    Sep 2008
    Brisbane, Queensland
    1. Unplug your cars battery for 30 minutes, hook it back up and see if it improves over a few days (so the ECU can recalibrate itself) ........... if you've never done it before. This usually helps.
    2. Your car has issues........ *who knows* take it to a proper holden dealer who can plug in a proper diagnostic tool to see whats going on.
    2009 VE SS SILVER SEDAN - Twin Amps... Tune in progress (more for response and power) then outright KW on a dyno
    Little Red VZ Go-Kart's Avatar
    Little Red VZ Go-Kart is offline Middle-age mutant ninja
    Ex-CFA VZ 175 Commodore Exec. 06 wagon
    Aug 2010
    Democratic People's Republic of Highton / Geelong
    Some possibilities, but like the foregoing posts, how are we supposed to know without seeing the car??
    Dirty MAF screen => Inspect (do not touch); clean as required with CRC MAF cleaner. The ECU will alter throttle response to any dirt or fouling on the MAF
    Too many short runs => take on 100-110km/h highway-freeway run with a tank of premium unleaded. Stop excessive around town/short runs as it builds up deposits
    Dirty injector(s) (usually notified by a trouble code) => 2-3 tanks of premium unleaded + in first tank, add injector cleaner
    Spark plugs => (requires inlet manifold removal) inspect for deposits and correct gapping. When was the last change?
    Fuel filter => past serviceable
    Fuel pump => sluggish performance sometimes a precursor to failure of fuel pump; as it progresses, engine can stutter, be hard to start, stall in reverse or on low fuel.
    I am not in favour of disconnecting the battery to clear the ECU, which can make diagnostic interrogation by techies difficult with no data to fall back on. Do a "soft reset": place car in idle, handbrake on. Slowly rev the engine to 3,500 and hold steady for 10 seconds to reset ECU. Release then drive.
    Bigdaddycool made a good suggestion to have the car seen by Holden for tech2 interrogation. Otherwise it's a lot of guesswork without actually seeing the car and sitting in it. Problems that require service are notified by trouble or error codes that can be interrogated from the cluster; tracing/interpretation is best left to Holden, not DIY.
    •:*¨¨*:•.When you start your car, does it return the favour? •:*¨¨*:•.
    Originally posted by soop
    Your arse is going to sting for a while, and then worse when it does bugger all.
    Vz Sv6 04
    Nov 2009
    Bundaberg
    im gonna try and soft reset on my car see if it makes any difference cheers for the info
    May 2010
    thanks for the posts all, iv had the terminals off for that long and still nothing,i run only on premium and every couple weeks i run injector cleaner through it,last service i had the fuel filter changed and still nothing its been doing it for about 6 months now maybe bit longer now with the sluggishness cold air pod style filter wouldnt change that would it? as for tyres i have gemstones and sounds like its coming from the front but as i stated before iv had the front wheel bearings looked at...
    VZ A4 Saloon
    Nov 2010
    Is the air pod an oil impregnated type? May need to clean MAF sensor if it is.
    May 2010
    May 2010
    still cant fix it,as much as i trust Mace Engineering might take cold air out see if that fixes it if not got no idea what to do next
    VZ A4 Saloon
    Nov 2010
    May 2010
    May 2010
    all good,getting a good tune up done soon hope that fixes it!
  1. Rear AUX volume extremely low.
    By vn4250 in forum VE Holden Commodore (2006 - ?)
    Last Post: 01-11-2010, 10:02 PM
  2. !!my extremely clean vr series 2 commodore:)
    By slappedvr in forum VR - VS
    Last Post: 08-10-2009, 10:26 AM
  3. Extremely P'd off!!
    By Longman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-08-2009, 05:22 PM
  4. Extremely Thin Oil!!!!
    By vsiicalais in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-01-2008, 04:13 PM
  5. extremely cheap vx ss
    By greenvs in forum General
    Last Post: 23-12-2007, 10:22 AM
