Results 1 to 11 of 11
Thread: Why does my VZ Do this
    VE Berlina
    Mar 2011
    Question Why does my VZ Do this
    Whys my VZ doing this?
    Hey guys,
    Okay few question about my VZ Executive
    1. Why does it putter away from stop start? aka stopped at lights then foot down to take off the putters away barely goes anywhere the finally kicks in and goes.
    2. At gear changes fan belt seems to squeal, mostly on high rev gear changes. Why does this happen?
    3. At 110km car vibrates and gets worse faster you go?
    4. Between 75km and 85km doesn't know wether to change up or down?
    Any help would be great 
    2006 SX6 Adventra
    Apr 2010
    Give us some more stats
    V6 or V8??, 175kw/V6 alloytec i'm guessing...
    How many ks.....?
    4 speed or 5 speed auto?
    service history....?
    Could be fuel/coils/basic tune.... how have you been driving it.....??
    VE Berlina
    Mar 2011
    2004 V6 alloytec 200,000kms, drive it hard everynow and then but nothing to mayjor
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    Hard to tell unless someone's there with you. The Alloytec isnt like the Ecotec, it does take "some time to wind up". theres heaps of threads about its sluggish down low etc.
    When your really thrashing it it happens, because the coolant pump cant slow down quick enough when the shift happens, so the belt slips on the pulley until the 2 sync again. Just watch your tacho, you'll see the needle suddenly drop revs at the change.
    Could be wheel alignment. Could be rim balance. Could be front hubs
    Thats normal for the 4 speed gearbox, just pick what speed you want (I assume your trying to sit on 80 for an 80kph road) and keep it there. Tapping the accelerator readies the car to move, so it shifts down ready to pull ahead, but then when you back off it re-adjusts itself, shifts forward and runs with it.
    VE Berlina
    Mar 2011
    Thanx alot Torquative clears up most of it.
    Could vibration be caused by shit tires?
    Yea i heard they dont have the same pick up, but it shouldnt putter should it? cause you can phyically hear it putter away that finally kicks in.
    so no way to stop belt squeal?
    Vsfan95's Avatar
    Vsfan95 is offline Vsfan95
    VT Series 2 Acclaim
    Dec 2009
    one the reasons you cold be getting belt squeal is probably because the drive belt main tensioner assembly is going. My old VS had the same problem and the belt flew off because off it and that same problem caused it putter off and then kick in
    If its Found On a Rubbish Dump its a FORD if it is Holden On its a Holden. Pick your poison.
    VE Berlina
    Mar 2011
    Great now my power steering pump has stuffed up and man is sh*t to turn with out power steering (Not Happy)
    6h84eva's Avatar
    6h84eva is offline Certifiably Holden Mad
    2004 VZ SV6
    Sep 2004
    Papakura, Auckland, NZ
    I've driven a VY S which was real bad on takeoff (stuttered, puttered and generally just thought about moving rather than doing it) until I turned off the TC. Noted better takeoff in my VZ SV6 when I did the same thing....and it's also possible to really get those tyres smoking wildly in this state!
    "Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." ~ Samuel J. Clemens
    04 VZ SV6, 106km, leather, A/S, TC, 2-onr - my baby
    97 VSII Exec wagon, 187+km, 2-onr - family transport (poor thing)
    WL CAPRICE
    Mar 2011
    is your car running LPG?
    if so my wl stato used to stutter because the tune was out by miles.
    after getting the gas serviced and tuned the car is running perfect.
    another reason that was causing mine to stutter was the coils, i checked them out
    WL CAPRICE
    Mar 2011
    this is sort off normal if its not way too abvious, what i mean by this is,
    lets say your crusing at 75km then you decide to pick up speed to takeover, the car hesitates to pick up speed and change gears.
    if you have to plant your foot inorder to get it to pick up speed and change gear then it may be your torque converter.
    is there a vibration throughout the car at that speed between 75 -85km?
    if so its more likly to be your torque converter.
    hope i helped
    Dave
    CRUSTIN is offline P-plater
    VZ S 175 Ute
    Nov 2010
    Ive heard the vz computer has anti thrash software that prevents the engine from producing too much torque down low to protect the diff and gearbox. vcm suite can get rid of it.
    Originally Posted by Little Red VZ Go-Kart
    1. Why would you want to floor it, or move it to the red line? Especially with the lack of airbags and ABS features!? What do you hope to achieve by that??
    Originally Posted by HoldenV8
    give everything a spray with wd40 wheels brakes that should fix the squeaks
