Results 1 to 3 of 3
Thread: Would this exhaust fit together, No welding or cutting required?
    VZ SV6
    Feb 2011
    Default Would this exhaust fit together, No welding or cutting required?
    So yeah would this fit together easily, my mate is a mechanic and said he can do it but its harder if he has to cut stuff and would pref it be all bolt together and easy.
    2 1/2 Redback catback
    Pacemaker extractors
    Magnaflow 2 1/2 inch cats
    Thanks
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    i dare say no... the standard pipe between cats and extractors is a little bit smaller then the size of the cats.. will need to weld/cut
    Life starts at 200km/h
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Pacemakers have a loose flange that comes with the extractors, they need to be welded. The cats are universal, they will need to be welded in.
    I do a bolt on system but it's not cheap. All up about $1800, Hurricane extractors, high flow metal cats, and a twin 2 1/4"into 3"single. All bolt up, has the four O2 sensor fittings for the SV6 as well.
    Visit my Facebook page
  1. Vl rear ended badly. opinions on cutting out and welding in new panels
    By 88-SERIES200 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-12-2010, 08:07 PM
  2. Vl rear ended badly. opinions on cutting out and welding in new panels
    By 88-SERIES200 in forum Spray Painting and Panel Beating
    Last Post: 02-12-2010, 09:24 AM
  3. Full exhaust to fit perfect as supplied, no welding or cutting, DOES THIS EXIST??
    By savage1987 in forum VE Holden Commodore (2006 - ?)
    Last Post: 28-03-2010, 01:15 PM
  4. exhaust welding
    By Rg123 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-04-2009, 06:55 PM
  5. Cutting Exhaust Tip!!!!!!!
    By Troyziee in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-11-2006, 04:10 PM
