Results 1 to 6 of 6
Thread: Heavy Shuddering Low Rpm Med/High Load
    VZ Exec Wagon
    Jan 2011
    Newcastle
    Default Heavy Shuddering Low Rpm Med/High Load
    Hey guys.
    Just started happening in the last couple of weeks.
    Car is 05 Auto Exec Wagon.
    This usually happens when in D and it shifts into 4th and then locks up the stall converter which drops rpm to ~1500rpm. The car will then proceed to labour and 'bunny hop'/surge.
    -If I back off throttle slightly it usually stops.
    -If i get it to kick out of stall converter to higher revs it is fine. It is also fine @100km/h
    It seems that it only happens at those specific revs and load.
    Suggestions?
    Anyhelp would be appreciated.
    Thanks.
    Big Tone.
    p.s. Does anyone have a Blaupunkt Single CD H/U for a VZ going cheap?
    04 VZ SV6 A5
    Feb 2010
    i have a very similar problem with my sv6 5speed auto, surges in top gear, holdens diagnosis is a shagged gearbox which needs replacing but on doing some further research it has something to do with the torque converter not fully locking and "chugging", although have not had this confirmed by a specialist yet
    jdrVZute's Avatar
    jdrVZute is offline Donating Member
    Vee Zed Ute
    Feb 2011
    Redhead, Newcastle
    I've got a headunit sitting at home I may not use, I'll get back to ya on it
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    Sounds pretty much like the converter is slipping when it's meant to be fully locked up - so it's cactus. Does the lock up and unlock of the coverter seem abrupt, loud or not very smooth? You should barely even notice the converter locking up, other than the slight drop in rpm.
    Quagmire: My fellow Americans, I have not been entirely truthful with you. I did gagoogidy that girl. I gashmoygadied her gaflavity with my googus. And I am sorry.
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
    Torque convertor control (TCC) clutch system. Specialist repair.
    These types of products may work. And it's in a tube! What will they think of next.
    VZ Exec Wagon
    Jan 2011
    Newcastle
    The actual locking/unlocking of the converter is smooth. I just drove 300kms @ 100-110kph and it had no worries, only in the last 50kms of 80 zones it did it a bit and med/high load up hills when it was locked at 80kph.
    Sometimes there is a waivering of revs only by a couple of hundred to indicate it wanting to lock up or something.
  1. vy shuddering
    By pauled15 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 15-12-2010, 09:31 PM
  2. VP shuddering
    By T3T4VT in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-10-2010, 09:34 PM
  3. engine cutting out when cruising+under high load
    By gambit120 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-09-2005, 05:03 PM
  4. Shuddering
    By kim_08 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-09-2005, 01:34 PM
  5. VR Shuddering at take take off
    By wakesetter_boarder in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-08-2005, 01:36 PM
