Results 1 to 22 of 22
Thread: Im so over mechanics
    vz equipe 3.6
    Sep 2007
    gold coast
    Default Im so over mechanics
    Today after driving 50km mostly highway i hear shh shh shh shh from the back wheel with every revolution,so i decide to call a well known mechanic and i told them i think its the brake shoes rubbing but that was just my opinion.so the pulled every thing apart and scuffed up the inside of the roter and there was a little surface rust there.Then they took it for a drive and heard nothing and i was happy.Driving back tonight i wind down my window on the highway off ramp and here SHH SHH SHH i was so peeved off so im thinking that it has nothing to do with the brake shoes and maybe the caliper anyone had this problem and solved it thanks
    Vr ss & vy v6 wagon
    Jan 2010
    Central Coast, NSW
    on your vz? it will be the handbrake not quite releasing properly and just touching where it grabs onto,my vy does it also
    VB SL/E
    Dec 2008
    Don't start me on lazy good for nothing and outrageous charging mechanics, dangerous horror stories, I can name a one or two to avoid...
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    mine does it also, i notice it more if i park on a downward slope and pull up the handbrake and let it rest on the handbrake then release it. always makes the noise and has peeved me off for ages. if you find whats wrong with it, let me know so i can try to fix it. havent looked at the handbrake yet because i dont know how to adjust it properly :S
    Spoken by a true member of The Committee
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    LOL if you're going to bitch about Mechanics by a manual, learn how it works and do it yourself.
    Its when you take a car to them because you'd rather pay someone to do a shit job, you explain the symptoms and tell them EXACTLY what you want fixed and they don't do it, but charge you for a completely seperate job that doesn't fix the issue, I get pissed.
    vz equipe 3.6
    Sep 2007
    gold coast
    Thanks for your input so far guys.yes its a vz adds.Cost me $82.50 to get this work done today.This is the 3rd time in 6 months that my handbrake has been adjusted and the mechanic reckons the sound was caused because on the previous adjustments by them not tightening the cable at the brake shoes.Im taking it back on monday and they will fix it again.Also my rotor's have been machined to a shiny finish and my pads are only 6 months old so im not sure.reading google comments it could be: sticky caliper,warped rotor,hot spot on disk,caliper pins out of round.IM JUST OVER IT ITS BLOODY LOUD AND EMBARRASSING AND MAKES IT SOUND LIKE A FORD :boxing
    vz equipe 3.6
    Sep 2007
    gold coast
    Quote Originally Posted by soop View Post
    Its when you take a car to them because you'd rather pay someone to do a shit job, you explain the symptoms and tell them EXACTLY what you want fixed and they don't do it, but charge you for a completely separate job that doesn't fix the issue, I get pissed.
    I was 50km from home when i heard it today but i reckon i could do a better job than those slackos.Since september ive had the front and back brakes done and from that i had a pulsating pedal and took it too them 3 times and not once did they feel the pedal or the rattle from the loose anti-rattle clips.I took it too another brake specialist who did a mirror finish on my rotors and machined my rear rotors because i had this noise.Had a full service done in december and got home and developed lifter tick.and now today WTF
    vz equipe 3.6
    Sep 2007
    gold coast
    Quote Originally Posted by richardpalinkas View Post
    Is yours loud richard as mine is louder when in an echoey area like driving beside a fence or wall or barrier but if i put my head out the window i can still hear it.And its only happening on the longer drives at this stage
    Nov 2008
    Smithton, Tasmania.
    commodore
    Aug 2009
    australia
    my dad had a new booster installed by a mechanic along with a rwc, he drove out of the workshop and first time he had to stop he nearly went up the arse of the car in front took it back and they said it was normal mind you he had to pump the pedal three times to get the brakes to work everytime he wanted to stop, since then ive always done his brakes and all his work and hes had no problems with so called mechanics, as soop says buy a manual and learn how to do it yourself you save bucketloads of cash and know its done right.
    vz equipe 3.6
    Sep 2007
    gold coast
    Quote Originally Posted by bogan_vk View Post
    That happened in my vs after getting new pads and rotors installed on the back i just got off the highway and the brake light came on and i had to put my foot thru the floor to stop it but i put that done to an air bubble and it never did it again but i did crap myself
    May 2009
    Gold Coast
    Quote Originally Posted by mike4226 View Post
    yea mine is a lound whoosh noise on drivers rear wheel. is very embarrasing, so i just try to not park on down slopes haha. il get around to adjusting it myself to see if it helps. havent really noticed on longer drives, but i dont know what 'disengages' the noise, because its there, then its not, then its back. at first i thought it was my rotors, so i replaced them. seemed to work for a few months, then came back, so i doubt its rotors
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
    The rear handbrake system is cheap and poorly designed. It's used in many other vehicles throughout the GM empire.
    If you manage to get it fixed, it will go out of adjustment and begin making noise again quick smart.
    vz equipe 3.6
    Sep 2007
    gold coast
    ye its probably not your rotors as mine have a mirror finish.I read on google in a ford forum that the ba falcon had this problem and an easy fix was too drive forward a few metres and than put the handbrake on and reverse 2 metres and apparently that works
  15. #15
    vz equipe 3.6
    Sep 2007
    gold coast
    Quote Originally Posted by heyitsEnricoPallazzo View Post
    If you manage to get it fixed, it will go out of adjustment and begin making noise quick smart.
    hey enrico has it happened to yours before??
  16. #16
    May 2009
    Gold Coast
    so your saying reverse 2m with the handbrake on? lol funny story, the noise was peeing me off big time one day, so i reefed up the handbrake, prob only going about 30km/h, and heard a big ass bang. wont do that again hahaha
  17. #17
    vz equipe 3.6
    Sep 2007
    gold coast
    yes Richard roll forward and put the handbrake on and keep it on and reverse 2 metres.One lady who was having this prob in her ford did it and she didnt get the sound again.So i guess it positions the brake shoes or something like that
  18. #18
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    haha did that one day in my dads VX cause they were rubbing and it was annoying me but i also got a real loud screech cause they just locked. Found out there either on or off and nothing in the middle lol
  19. #19
    VZ A4 Saloon
    Nov 2010
    All the time. Sick of adjusting the things!
    The handbrake shoes have adjustment pawls which are reached via holes it the disc hat. Easy to adjust but are prone to seizing.
    The pawl locking tabs are also shite.
    The Fords must have automatic adjusters on the HB (activated when brakes are applied in reverse). Kingswood's used to have this system many years ago.
    Done that too!
  20. #20
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    I remember that in the Kingswoods, too. Just a thought, probably not what's causing it but my VY was doing this same shh, shh, shh noise a couple of weeks ago. It was the backing plate on the inside of the rotors, had bent slightly and was scraping on the rotor. I just bent it back into shape and noise was gone.
  21. #21
    vz equipe 3.6
    Sep 2007
    gold coast
    Quote Originally Posted by VYMAD View Post
    I reckon its that too.after 3 hb adjustments in 6 months and its never gone away
  22. #22
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    They probably over adjusted at the rotors. Generally you wind the shoes out till they lock then back them off a certain amount of turns. If you dont back them off enough, you get that noise and in some cases even a vibration at freeway speeds.
    Silver Certified.
  1. mechanics help please!
    By airforceone in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-07-2010, 07:22 PM
  2. Any mechanics out there? Help.....please!
    By redtamada in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-04-2008, 03:09 AM
  3. Rip off mechanics
    By hotrod32 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-06-2006, 01:00 PM
  4. Is There Any Mechanics on here
    By Phoenix21 in forum General
    Last Post: 14-05-2006, 08:28 PM
