Results 1 to 5 of 5
Thread: VZ ute, radio turns on by itself
    VZ ute
    Mar 2009
    Default VZ ute, radio turns on by itself
    After locking up and some time later, hours, the radio is belting out tunes and if I haven't switched off the wipers they are dragging the windscreen dry too.
    It doesn't happen all the time just a hand full of times, but you have to switch every thing off, before turning the key off and locking up.
    I'm guessing the barrel is on the way out, I will try a bit of graphite powder first, but has this happened to any body else or have I got a poltergist living under the dash. Ghost busters I hear you.
    Cheers,
    Peewee
    and good work every body.
    Little Red VZ Go-Kart's Avatar
    Little Red VZ Go-Kart is offline Middle-age mutant ninja
    Ex-CFA VZ 175 Commodore Exec. 06 wagon
    Aug 2010
    Democratic People's Republic of Highton / Geelong
    Hmmm. A VZ beaut-ute with new, improved levels of automation... .
    Cool. Way cool.
    Radio can normally be turned on by pressing ON/OFF switch irrespective of lock/unlock running or no state, so maybe button is sticky?
    Wiper control should be off and remain off; I cannot imagine how they would operate unless the stalk is in the switched-on position. But pointedly: dragging wipers on a dry screen will scratch it. This glitch really does need urgent intervention.
    •:*¨¨*:•.When you start your car, does it return the favour? •:*¨¨*:•.
    Originally posted by soop
    Your arse is going to sting for a while, and then worse when it does bugger all.
    VX Calais s1 l67
    Sep 2008
    Perth Australia
    .. to be honest mate thats freaky.. ild disconect the battery for 15 mins and reset the pc.. and see if the problem persists.. also give everything a nice clean
    2000 VX Calais L67 !!!
    When you walk up to opportunities door - don't knock it..Kick that b*tch in, smile and introduce yourself.
    1DVSBSTD
    ashbox's Avatar
    ashbox is online now 6 speed
    VZ SS 6 Spd
    Apr 2007
    The Car
    could even be the door switch, i had this problem with my old vz..
    Chev badges are an instant fail
    vz ute
    Nov 2011
    perth wa
    its happened to me a few times radio on lights on and doors unlocked, happened so much it drained my battery got a new one and it hasnt happened again..
  1. Radio turns on when car is locked?
    By antali2 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 01-09-2011, 07:41 PM
  2. VS Exec radio to Calais radio
    By Super Coach in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-11-2010, 07:43 PM
  3. VT V6 turns itself off
    By Dean garrigan in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-07-2010, 06:04 PM
  4. Sub amp turns off?
    By Ray De Man in forum Car Audio
    Last Post: 05-05-2010, 09:29 PM
  5. Help. Air con fan turns itself off
    By veeque92 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-03-2006, 06:57 PM
