Results 1 to 22 of 22
Thread: Tire Pressure for Track Day's
    Monaro CV8 Series III
    Mar 2011
    Default Tire Pressure for Track Day's
    Hi Guys,
    I have a track day next week (wooo) in my Monaro CV8 Series III. I run Pirelli Dragon's 235/40z R18's and wondering what you would recommend a good tire pressure to start with would be. I understand that tire pressure will need adjusting on the day for best performance, but wondering from your experience what you would recommend. Cheers!
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    drop it to around 22-25 psi i reakon, but when you have time, just drop it down to 30psi, then drop it in increments of .5psi until you start to get a slower eta. there is a thread called drag racing 101, just search for it
    Spoken by a true member of The Committee
    ashbox's Avatar
    ashbox is online now 6 speed
    VZ SS 6 Spd
    Apr 2007
    The Car
    Quote Originally Posted by richardpalinkas View Post
    is he drag racing or full circuit?
    Chev badges are an instant fail
    A bicycle
    Aug 2009
    Gippsland, Victoria
    i have a great article on tyre pressures in a magazine, will try to find it for you.
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Quote Originally Posted by NonStick Squid View Post
    @old mate you drive a vs ute therefore you're a bogan therefore your point is invalid
    VZ
    Jan 2011
    i would have thought around 35 or 40 PSI would have been better for a track day, as the tyre under more pressure therefore less resistance?
    A bicycle
    Aug 2009
    Gippsland, Victoria
    no its not about resistance, its about controlling tyre temperature.
    ideally, i think you want a difference of about 4psi from cold pressure to when you come off the track (hot pressure). if you run a too low pressure, the tyre will overheat and the gain in pressure will be too much and will have an adverse effect on tyre wear. obviously the car wont have much grip.
    and if you have too much air in the tyre, it will struggle to get heat and the pressure gain will not be enough.
    i have a feeling, that around 31psi front and 32psi rear will be a good starting point. obviously with different tyres these pressures move around a bit. but make sure you take a book and measure the pressures before and after every session.
    May 2009
    Gold Coast
    woops, i thought he meant for 1/4 mile runs hehe. no idea for track, id probably run the same as street pressure. but i wouldnt have a clue
    Mar 2011
    Hi guys, Track Day next week is full circuit, so need the correct tire pressure for cornering and handling. My understanding is that too low pressure will cause the tires to roll on themselves, and too high pressure will cause them to be too stiff and not enough grip. 'Old Mate' you make a good point about temperature, if you could find that article that would be a great read.
    Recommended tire pressure for the car is 32psi standard and 36psi for high speed (Greater than 160kms, for normal load). I was going to start at around 36/37PSI cold and see how it goes, but after thinking about temperature, it might be best to start at 31/32 cold and in theory it will be 36 when it heats up… Will defiently be taking a book though (and a pump).
    TI3VOM's Avatar
    TI3VOM is offline VT V6 wanting 300RWHP
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    How long have you had the dragon's for, and how much did they cost?
    What else has been done to the car mate?
    VT V6 fitted with DMS gold 40mm coilovers, Whiteline adjustable swaybars & strut brace, 330mm AP racing brakes, Rebuilt 3.45:1 LSD and a Powerdyne supercharger
    Check it out: http://forums.justcommodores.com.au/...-v6-racer.html
    Mar 2011
    The Dragons I have had for around 18 months now, got them for $215 each. The car has had a MAFLESS tune and cold air induction (OTR). Got about 90 extra KW's out of her - she's now pushing 221KW@164KPH (on the Dyno).
    ashbox's Avatar
    VZ SS 6 Spd
    Apr 2007
    The Car
    Quote Originally Posted by craigsmonaro View Post
    bit off topic but what was the car running before the tune and otr....
    90kw gain and to only be putting out 221kw..?
    CRUSTIN is offline P-plater
    VZ S 175 Ute
    Nov 2010
    Maybe he meant RWKW? But i doubt a tune+OTR would do that.
    Originally Posted by Little Red VZ Go-Kart
    1. Why would you want to floor it, or move it to the red line? Especially with the lack of airbags and ABS features!? What do you hope to achieve by that??
    Originally Posted by HoldenV8
    give everything a spray with wd40 wheels brakes that should fix the squeaks
    VR Commodore V6
    Sep 2008
    Sydney NSW
    I'd probably start on about 27-28, depending on how well the car hooks up as it is.
    If the tyres really bite into the road, they'll generate more heat through sidewall flex, so you need to minimise the amount of flex, and therefore heat generated, but keeping pressures right.
    When you think about it, you can go quite low, depending how hard you push. Obviously you won't be going as hard as the V8 Supercars, but they run starting pressures of around 18psi
    Quote Originally Posted by PaRaDoX View Post
    btw do you plan to fly? looks like you have a gauge for everything, refreshment levels gauge, washer fluid temp? penis pump vacuum? *runs and hides*
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Why is "power" so important? Do you have a little dick?
    People are too obsessed with how much "power" their car makes....it doesn't make power, it produces torque, from which this mythical "power" figure is calculated.
    A bicycle
    Aug 2009
    Gippsland, Victoria
    i still cant find that article, its driving me insane. i should have a few hrs tomorrow to look for it though.
    in reference to the v8 comment, alot of slick race tyres need lower pressures to be in their ideal operating temperature range. i know that with my racebike i need to run around a 25psi area when the tyre is on the warmers, so thats around a 20 - 22psi cold range. but if you were to run a street tyre at that pressure, you would likely tear it to bits.
  15. #15
    Darcon666's Avatar
    Darcon666 is offline Evil is always around you
    The Wife
    Jun 2010
    At home
    I run Bridgestone RE55S 245/40/18's (http://www.bridgestone.com.au/tyres/...ort/RE55s.aspx) @ 28psi and at the end of a three lap super sprint they are @ between 38-40psi(This is @ Wakefield Raceway)but I like them firmer @ that track.... others prefer them softer so they aim at 24-26psi cold starting pressure --> and end up @ between 34-36psi. Eastern Creek on the other hand is completely different kettle of fish, I start them at 24psi and end up @ 38psi as the track is more abrasive and generates more heat into the tyres and so ends up being higher.
    As stated by others... I would start them @ 30psi, do 3 or 4 laps come in check... anything above 40psi is too much for the circuit you are on. Drop them by 2psi and go again for another 3 or 4 laps and see how they feel then come in and check, continue this until the car starts to NOT feel comfortable.
    Alternatively, find a store that has nitrogen and empty all the air out and fill... as nitrogen does not expand when hot. So you start @ 38 cold and you end up @ 38 hot but the tyres in my books feel strange, but that's just me.
    Just my 2c... *lol*
  16. #16
    TI3VOM's Avatar
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    Very nice power your making there mate, it would be fun to drive!
    One thing though, when the tires are worn upgrade to some better rubber for the track days, at the moment mines running Pirelli PZERO NERO's that I picked up for $208ea that's for 17" wheels mind you, they perform very well.
    Do you have anything done to the suspension?
  17. #17
    Mar 2011
    OK so this is what I think I will run with (track day is tomorrow). Start with (cold tires) 45 front and 42 rear, do about 3-4 laps to warm up, then bring down the pressure so they run at 43 front and 40 rear (hot). Obviously see how it goes and adjust slightly, but I am thinking higher rather than lower. Given I am running at Wakefield it is predominantly a right hand track so the pressure in the right hand tires will be different to the left, so the idea is to even them out so even pressure across each side. My only concern is that 43/40 may be too high…
    For those that were wondering, I have attached my Dyno stats of before and after the tune to give you an idea what I have got. Can’t wait – will be a fun day.
  18. #18
    ashbox's Avatar
    VZ SS 6 Spd
    Apr 2007
    The Car
    sorry but wtf.....
    132.4kw before tune and 153nm torque?
    if you re-read darcons post, he recommends 28 psi cold for wakefield top be at around 38 -40 hot
  19. #19
    A bicycle
    Aug 2009
    Gippsland, Victoria
    best of luck but 42f 45r cold pressure is too much.
  20. #20
    Mar 2011
    Well, track day's been and gone, and yes it was a brilliant day! Track time in the Monaro was 1min19 - pretty happy with it! Got a few ideas of what to do with the car next, but I will start a new post on that one.
    Anyway back to tire pressure, I was a bit optimistic in my last post - I started the day with 38 cold in all tires, and found I was constantly letting the air down during the morning - Settled with 42psi hot in all tires. Car felt nice and gripped well, wasn't squeaking and tire wear was even. I kept the pressure a bit higher based on some 'professional recommendations' from some of the guys at the track. I can't comment on if it would have been any better with lower psi (eg 38 as Old Mate recommended) but I was really happy with how the car went, well apart from the brakes but that's a whole other topic…
    Thanks everyone for your advise - it defiantly helped.
  21. #21
    A bicycle
    Aug 2009
    Gippsland, Victoria
    which track was that? the track is great fun, but defintely you get to see the weak points like brakes and power steering.
  22. #22
    Mar 2011
    Wakefield - defiently some weak points - brakes being the biggest then tires and suspension. Steering was OK though...
  1. tire pressure
    By lion_g in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-03-2011, 09:39 AM
  2. Tire Pressure + Bits and Peice's
    By JohnyRock in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-03-2010, 12:17 PM
  3. Tire Pressure!!!!!!!
    By Joey_21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-05-2007, 06:17 PM
  4. Tire Wear?
    By RhysVR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-11-2006, 05:06 PM
  5. Vr Commodore Tire Pressure
    By Steve27 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-07-2006, 12:28 PM
Tags for this Thread
